587,833 active members*
3,554 visitors online*
Results 1 to 7 of 7
Hybrid View
    Jul 2006
    1062
    Smile My new router.
    Well, late last year I realised that a larger router was needed.....So I started to build a new one from parts I'd acquired a year or so previously.
    First picture is my old router....It lasted less than 15 minutes on ebay before it sold, which was either testament to it's quality, too cheaply priced, or it just looked pretty?
    Then the pictures of the new router taking shape.
    The frame is 50x50 3mm wall steel tube, the uprights are 2mm laser cut mild steel and the ballnut mounts are 2mm MS laminated laser cut items.
    the ballscrews for X and Y are 32mm 10mm lead ground items and the Z is a 16mm 5mm lead unit.
    It will be a stepper driven machine with 2 motors on the long axis.
    The spacers on the uprights are 3/4" with a 1/4" hole, the bearing carriers are MS 47x50mm and 270mm long.
    The ballscrew bearings are 35x15x11mm and not AC type.
    Tomorrow I scrounge some materials to make the Z axis.
    Keith
    Oct 2009
    272
    Kipper,
    That first machine was/is PRETTY! Furthermore, your second machine ain't no slouch by any means. Very nice build.
    What do you plan on using your new machine for?
    Keep up the great work. I'll be following your progress intently.
    Randy,
    I may not be good....
    But I am S L O W!!
    Jul 2006
    1062
    Hi Randy, Thanks for the kind words!
    The new machine is intended solely to drill/machine Aluminium sheet items 1.1 meters long with around 200 holes in each piece....hopefully accurately
    Z axis travel will be around 75mm as it's mostly sheet materials I need to process.
    Keith
    May 2010
    307
    neat to see a build using sheet metal as you have. well done.
    Jul 2006
    1062
    Well....the Z has made very slow progress........
    Keith
    Jan 2008
    853
    Kipper, could you explain the gantry motion of your first machine? I see a drive screw and a belt mechanism; does the belt transfer power to the other side of the gantry motion?
    Cheers!
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
    Jul 2006
    1062
    Exactly right Paul....It transferred across with a shaft and a matching belt at the other side
    Keith
  1. Buying a new 48x48 Art-Router 4 Axis CNC Router
    By Stoch in forum Open Source CNC Machine Designs
    Last Post: 12-17-2010, 01:08 PM
  2. with a Precix Table Router with Perske router
    By SignShop Grunt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2010, 10:08 PM
  3. Building a CNC Router; by someone who can't build a CNC Router
    By Womble in forum DIY CNC Router Table Machines
    Last Post: 09-27-2008, 01:51 PM
  4. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
