587,513 active members*
2,847 visitors online*
Results 1 to 5 of 5
    Feb 2005
    149
    My Mill Drill Conversion project
    I would like to start on my Mill Drill conversion. 3 axis X,Y,Z
    The mill drill is very much like the bench mounted Harbour Freight that I see bein used in these threads. Mine is and Eagle25
    Any help at all on drawing etc pictures etc would be vey helpful,
    I started by buying a 3 axis stepper controller and 3 servo's Nema 23 size 1.7v at 4.7A these are 0.4Ohm and 200S/R 6 wires. I think I would like to go down the route of Servo's instead of steppers so I may trade my controller and steppers in.
    I would like some advice on pro's n con's stepper/servo. My understanding is that the servo aproach is more reliable.
    Can anyone advise please, and a size and a source of servo's at a reasonable price.
    Many thanks
    George
    Mar 2004
    1806
    George,
    I used servos on my mill/drill (RF31) and the last set is rated at 48V 1000 rpm and the first set was 110V 6500 rpm. I changed so I could have
    1) MORE power
    2) utilize the power of the motors within their voltage rating (geckos are limited to an actual about 70V power supply)
    Now having said that, I like the servos as they are smoothm but it took some doing to get there. You will need encoders (steppers don't) and of course this entails more wiring.
    Plan your system out. Get your servos first (and make sure the drivers you select will handle the required voltage) See item 2 above
    Figure out what resolution encoders you will need if they don't come with the motor and how you will mount them! (Mine are mounted on the ball screws which would allow me to change the pulley sizes on the reduction unit without changing my setup parameters)
    THEN after you have your servos and drives, worry about the power supply!
    As to the source, I scrounged all the "surplus" sites I could find on the internet and that is where I found mine. The last ones are about 4" dia 6" long and weigh about 11@ ea!
    If you want some additional info, let me know.
    Art
    Feb 2005
    149
    Thanks a bunch.
    That sounds like good sound advice.
    I'll start and try to locate some servo's and encoderws.
    Cheers
    Goerge....
    Jul 2003
    123
    hello
    I used Geckos too cost more and need encoders
    timing belts and pullies easer than direct drive more cost again
    as have to buy 2 pullies and a belt for each axis bur dont have aliment problems
    as with direct drive
    3/4 inch roton ball screw over size balls in nut instead of 2 nuts with a spring
    in between the nuts have .002 thousands back lash
    stepper motors need that load resistor and you have to calculate what size
    to use and it gets Hot too gecos rule
    Mar 2004
    761
    sidecar82 - Hi from down the road in Jackson
    Wayne Hill
  1. Mill/Drill conversion coming right up!
    By balsaman in forum Vertical Mill, Lathe Project Log
    Last Post: 04-30-2009, 02:04 AM
  2. Sidecar's Mill/Drill conversion
    By sidecar82 in forum Vertical Mill, Lathe Project Log
    Last Post: 10-18-2005, 09:08 PM
  3. Square Column Mill/Drill Conversion
    By Jay Kyle in forum Vertical Mill, Lathe Project Log
    Last Post: 08-23-2005, 07:42 PM
  4. Harbor Freight Mill/Drill Conversion Log
    By Halfnutz in forum Vertical Mill, Lathe Project Log
    Last Post: 04-14-2005, 04:56 AM
  5. Eagle Mill drill conversion
    By Georgie in forum Vertical Mill, Lathe Project Log
    Last Post: 02-24-2005, 02:12 AM
