587,923 active members*
3,468 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > My Journey To The Perfect Drag Knife
Results 1 to 9 of 9
    Feb 2018
    6
    Hi Folks
    Just thought I would do a post on my trial and errors of making a drag knife
    I know this subject has been covered many times before on a lot of media
    platforms. but this one is quite unique especially if you are contemplating making your own..
    I was interested in buying one from Donek tools but after looking at there dimensions
    I would have struggled to fit to my 6040, cnc due to limited Z clearance and shaft size.
    My only option was to make my own, knowing the internet is full of variations of the donek drag knife. But alas all the plans I came across were very similar in size.
    So to work I went, I dug out a old unused Stanley blade from my tool box and set about getting the correct measurements using my vernier, I used Vectric aspire
    to create the profiles and went ahead and made one..
    Here's the result, But this is also where the hard fought journey began, more to follow..
    Feb 2018
    6
    Re: My Journey To The Perfect Drag Knife
    So following on from my last post, whilst using the Drag knife to cut out some cardboard box templates I noticed the blade was starting to dull, so time to order
    some new ones.
    Once they arrived I tried fitting one, but to my surprise the Stanley blade would not fit
    I paired up both my old blade & the new one only to notice that the Stanley logo and the dimensions had changed, I then got in touch with Stanley tools and asked if they had made any alterations to there blades, and they confirmed they had. Gutted!
    This meant I would need to get out the Dremmel to modify the insert, I was not confident in doing this for making it totally unusable, so I decided I would
    buy some more aluminium stock and make a new one plus I could make a 2nd
    but smaller profile drag knife for more intricate cuts..
    Now here's the mad thing, I was looking for a pen to write down my new dimensions
    and picked up a sharpie from my draw only to find it had dried out, I then had another
    rummage and found another one but noticed this was double ended, a thin and fat tip
    a either end, then all of a sudden I had a light bulb moment, then after many countless
    failed attempts at making prototypes this is the result…
    Feb 2018
    6
    If anyone is interested in seeing this drag knife being tested, i`ve uploaded a vid to Youtube
    ( https://www.youtube.com/watch?v=LvIUWtHxcdE&t=)
    Nov 2008
    412
    Can you post drawing of your cutter. Thanks.
    Forget about global warming...Visualize using your turn signal!
    Feb 2018
    6
    Hi
    I was asked if would share the Drag Knife plans
    here you go..
    Attached Files Attached Files
    Nov 2008
    412
    Thank you. Unfortunately I don't have way to open this file because is in CRV3d format. Can you upload it as dxf file ?. Thanks.
    Feb 2018
    6
    No problem here you go Iancut
    Apr 2014
    432
    Nice I tried this method but was not overly happy with the result on fine cuts so i went for the plotter knife in a spindle wiith a round magnet for holding and small bearings inside for the swivle .It is short and sweet a dream for gaskets and decals ,I keep forgetting it was two years ago.
    Nov 2008
    412
    Thank you.
  1. Drag Knife
    By aaron1869 in forum RFQ (Request for Quote)
    Last Post: 05-13-2021, 08:04 AM
  2. using a drag knife
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 05-10-2021, 12:03 PM
  3. drag knife
    By cocojack1966 in forum Other Machine Topics
    Last Post: 05-12-2014, 06:11 PM
