Originally Posted by
ttm
best I could make out on that blade it looked to have a max rpm of 1800 rpm, my saw runs 3200 rpm, any blades that can handle that rpm?
At that rpm the only blade for steel is an abrasive cut off blade but it is no good for aluminum. Also trying to cut steel thicker than about 1" diameter will be a long and noisy process.
For aluminum what you need is a 'triple chip' carbide blade made for non-ferrous metals. Freud is one brand but there are others. Something like 80 teeth or more will do a nice cut. On thick aluminum such as you want to cut it is a good idea to use coolant/cutting fluid otherwise the chips will sometimes pack in between the teeth and can cause a rough cut or even chip a tooth. If you don't have coolant you can use tapping fluid or ATF automatic transmission fluid just brushed onto the blade and workpiece before cutting. If you are doing lots of cuts proper coolant and a mister setup is a good idea.
EDIT: Forgot to mention make sure you clamp the work down very securely so your hand is well away from it. No hand holding the work when cutting aluminum. And (as mentioned) wear protective equipment, a full face mask as well as goggles is not a bad idea because very hot chips go everywhere.
