587,675 active members*
3,941 visitors online*
    Jul 2006
    83
    Moving X & Y axes
    Cant find a reference to moving the X&Y remotely or by hand(unpowered) and I need to clean or check the final mirror & lens. & Can you set the z table to move in continuous mode instead of pulses? TIA Dubliner
    Jul 2006
    83
    Scratch that . I didnt realze it was easier to move it in the control SW, thought you had to move it on control panel. I did notice that Z will move while Neg Z is held down, but X&Y still only work as pulses. Can you adjust that?
    Apr 2006
    251
    My Z axis was the opposite - it could only be moved in steps but the step length could be set.
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. Moving Table, or Moving Gantry? (For Router)
    By Cryptonic26 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2011, 08:38 AM
  3. SOLVED - Backlash compensentation causing problems while moving 2 axes
    By Hirudin in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2009, 06:03 AM
  4. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
