587,354 active members*
3,155 visitors online*
    Feb 2012
    29
    Question Motor Outputs: double Pin# by Axis ???
    Hello,
    Building machine with 3 axis, the Y axis need two twin motors.
    Then need equal signal by each motor.
    Ports and Pins, Motor Outputs:
    I try write double Pin# writing with sintax:
    Y axis Step Pin#: 8,5
    Y axis Dir Pin#: 3,4
    but the signal cable only activity on 8 and 3.
    So, how to setting double Pin# by Axis ???
    35538
    Set up one motor as the Y axis, and one motor as the A axis, and slave the A axis to the Y axis using Config >Slaving
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2007
    3734
    Those commas, went out when command lines evaporated.
    We assume you are talking about Mach3.
  1. TNC 145 DOUBLE AXIS ERROR - FOUND
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2008, 08:13 PM
  2. Double x axis drive
    By mrfreon in forum DIY CNC Router Table Machines
    Last Post: 02-22-2008, 01:03 AM
  3. How to drive double x-axis?
    By zone023 in forum Open Source CNC Machine Designs
    Last Post: 04-01-2007, 10:35 AM
  4. Y axis rail- single or double?
    By Corvus corax in forum Linear and Rotary Motion
    Last Post: 11-16-2005, 01:42 AM
  5. Double X-axis Drive
    By mícheál in forum DIY CNC Router Table Machines
    Last Post: 11-15-2004, 03:48 PM
