587,143 active members*
4,338 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Motion Control Board for Mach3 AND LinuxCNC
Results 1 to 5 of 5
    Jul 2007
    139
    Question Motion Control Board for Mach3 AND LinuxCNC
    I'm in the process of building a CNC router and I'm having a hard time figuring out what motion control boards would be compatible with both Mach3 and LinuxCNC.
    I'm looking for a high end board like an ehternet smoothstepper, but I haven't found any info regarding compatability with LinuxCNC. I want to find a board that's capable of running off of either as I'm somewhat familiar with Mach3 and a friend will give me his copy to use. I don't want to be stuck with Mach3 for too long though, as it's old software, and LinuxCNC seems like it is more robust and closer to an industrial grade control. I've got zero experience with it though, and I'd much rather transition rather than just jumping right in. I figure my best bet would be to use hardware that's compatible with both and see what works best for me. Any advice would be greatly appreciated.
    35538
    Re: Motion Control Board for Mach3 AND LinuxCNC
    None.
    They are not compatible with each other.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2012
    192
    What about parallel controllers?
    Sep 2009
    1856
    the G540 can do both there is a list under the linuxcnc 2.7 instructions
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Apr 2004
    733
    The g540 is a 4 motor stepper driver, it's not really a motion controller like a smoothstepper is.
    The last time I looked into this, Galil has some models that work with linuxcnc and Mach3. They are very expensive, even used on eBay. Support on both platforms may be little or none.
    The only motion adapter I would consider for LinuxCNC is the Mesa, about $100. This is the one that Tormach uses in their turnkey Pathpilot/LinuxCNC computers that are shipped with the CNC machines. Lots of users and a controller board that is well supported. Mesa is not compatible to Mach.
  1. X axis homing in Mach3 with a CS-Lab motion control board
    By Exhibitology in forum CS-Lab CNC Products
    Last Post: 05-03-2016, 07:32 PM
  2. questions regarding a good motion or breakout board for Servos and Mach3
    By want-to-be-cnc in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2016, 08:56 PM
  3. Replies: 0
    Last Post: 10-22-2011, 11:46 AM
