587,501 active members*
2,920 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Moriseiki SL6 Ladder Diagram - Fanuc 6T
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2005
    18
    Did anybody having ladder diagram for Moriseiki SL6 with Fanuc Controller 6T.I want the details to set the timer values as the values intialized.Please reply me.
    Problem: Turret is not properly indexing and it is over shooting or not in reach to limitswitch to close the clamping confirmation signal.Problem observed after initailization of bubble memory due to alarm 901 & 904.Parameters reloaded and ok. only timers values not known.
    Nov 2006
    175
    if you can not find it, post the plc chips here, I'll return in ladder text format
    Apr 2009
    6
    Timer values
    I have the exact same problem on my Daewoo lathe w/6T control. How and where do you set timer values?
    Apr 2009
    1379
    pc params
    To display the pc params press the param push button until top of screen says PC PARAM. Counters are params 2001,2002,2101,2102.
    keep relays are 3001-3004. Timers are 1001-1019 in msecs. To change counters, turn program protect OFF.
    Mar 2008
    31
    you may try these pc parameters settings
    1006 = 100
    1009 = 1000
    1010 = 100
    1014 = 8000
    1015 = 100
    3002 = 10000001 or 10010001
    3003 = 01000000 for 10 stations turret or 10000000 for 12 stations turret.
    Good Luck!
    Apr 2009
    6
    Thanks guys!
    I found the PC paramenters. But there are values in there but I do not know which ones to adjust for my turret. I need to set timer 3,4,and 5, for the turret functions according to the fanuc manual. Right now the turret timers are way too high and every function of the turret takes about 5 seconds before it excecutes. The book says for example timer 3 set to 200ms. How does this value get entered in the PC parameters?
    I also am not sure why the timers went high after the 904 alarm? you would think they would be zeroed out if anything. Thanks in advance for your help.
    Apr 2009
    6
    6T timer values
    PROBLEM SOLVED!!!! Thanks to your info I set the timers values and all is good. I answered my own question about which timer value from the manual coensides with what PC parameter. Timer 1 = 1001, 2 = 1002, etc. After the 904 alarm, all the timer values went to 6350. Does anyone now why? Are PC parameters backed up when I do a regular parameter back up?Thanks again for the help.
    Nov 2011
    0
    does the mori seiki sl-1 have a ladder screen to go to
    Sep 2010
    1230
    Quote Originally Posted by eastcomms View Post
    Not if the control is a Series 6. Machines equipped with this control were generally supplied with a Hard Copy of the Ladder logic. You may be lucky and still have a copy in the maintenance or wiring manual of the machine.
    Regards,
    Bill
    Aug 2010
    43
    Quote Originally Posted by f-bu View Post
    Hi there
    Can you get the ladder for 6TB if I give you the chip numbers?
    Can I convert the Rom info buck into ladder?
    Apr 2009
    1379
    The eprom ladder data cannot normally be read. The PC parameters cannot be downloaded; write them down.
    Aug 2010
    43
    Quote Originally Posted by memoryman View Post
    Hi Memoryman
    Thanks for the info on the ePROM. How do you get to the PC parameters. If I press parameter putton you only see up to P407?
    Apr 2009
    1379
    press the button again
    Nov 2006
    175
    Quote Originally Posted by vanwyksc View Post
    Hi there
    Sorry, just from the chip numbers, no. But from binary image of the chips, yes. You will need EPROM programmer to read the chips form PMC-model B board.
    And usually I ask for $40 for making ladder text graphics file.
    Aug 2010
    43
    Hi there
    Someone did download the 6 EProms for me, but not the 902 chips.
    Please send your email address then I can send you a picture of the board.
    What program do you use to convert it from binary.
    Have you got a example of one that you have done before?
    Nov 2006
    175
    PLC program is in the following chips:
    Attachment 195866
    here is text graphic example:
    Code:
      00005 |  *ESP.M    MRDY        *ESP  | EMERGENCY STOP
        1A  o---| |------| |---------------------------------------------------------------------( )---o 1C , 6G
            |  038.4    006.3        102.4  | 6K , 7A
            |             2A        | 7E , 9D
      0 28A |   OSP     * 23A     224C                                                           *SP   | 56B, 63A
        1B  o---|/|------| |------|/|------------------------------------------------------------( )---o 66B1B
            |  210.0    038.5    280.1                                                          102.5  |
            |    5K        |
      00012 |   ST.M     *ESP        B.SPS  | SPINDLE STOP
        1C  o---| |--o---| |---------------------------------------------------------------------( )---o 1E 11CI
            |  032.7 |  102.4        204.2  | 6M
            |        |    1A        |
            |   DST  |        |
        1D  o---| |--o        o
            |  066.5 |        |
            |  B.SPS |        |   105F
        1E  o---| |--o        o
            |  204.2        |
            |    1C        |
      00017 |  *ESP.M        HIDR  | HIDROON
        1F  o---| |------------------------------------------------------------------------------( )---o    1F
            |  038.4        000.0  |
      00019 |  LOG_1     M10A        *ITX  | INTERLOCK X AXIS.
        1G  o---| |------|/|---------------------------------------------------------------------( )---o    1G
            |  208.6    224.0        096.4  |
      00022 |  LOG_1     M20A        *ITY  | INTERLOCK Y AXIS.
        1H  o---| |------|/|---------------------------------------------------------------------( )---o    1H
            |  208.6    224.1        097.4  |
      00025 |  LOG_1     M50A        *ITZ  | INTERLOCK Z AXIS.
        1I  o---| |------|/|---------------------------------------------------------------------( )---o    1I
            |  208.6    224.2        098.4  |
      00028 |                                    ._______.                                             |
        1J  o------------------------------------o SUB 1 o---------------------------------------------o
            |                                    |  END1 |                                             |
            |                                    ._______.                                             |
    Aug 2010
    43
    Hi there
    Find the picture attached. Can You do all of the chips?
    What program do you use to convert it to the text layout?
    Nov 2006
    175
    You have PLC model A, not B. Necessary chips are these 6 2716 on the right picture(two upper, 241&242 are system plc soft, but better copy them too)
    set of programs needed, some my own made, some not
    Aug 2010
    43
    Hi there
    This is a 6T-B. The 6T-A the chips is on the main board. On the 6T-B the chips is on a ROM board that plugs into the main board. I have both type machines.
    What do you use to convert the chips binary into the ladder diagrams.
    Nov 2006
    175
    Hi there
    I wrote PLC model A, not the control, but the PLC
    see above: some my own made, some not
Page 1 of 2 12
  1. Replies: 6
    Last Post: 08-28-2013, 06:26 PM
  2. Fanuc 11m Ladder diagram
    By Selimsalim in forum Fanuc
    Last Post: 05-22-2012, 05:40 PM
  3. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
  4. Fanuc 16T Tornos ENC-167 ladder diagram
    By Jung in forum CNC Swiss Screw Machines
    Last Post: 11-19-2010, 08:49 PM
  5. LADDER diagram Fanuc OT
    By tano in forum Fanuc
    Last Post: 09-06-2010, 03:58 PM
