587,920 active members*
3,615 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki NL2000/500 lost zero point
Results 1 to 2 of 2
    Jun 2015
    9
    Hi.nl2000/500 losing x axis. alarm Z70 "ABS illegal Error" 0101
    How to zero point initial procedure?
    Sep 2007
    122
    Re: Mori Seiki NL2000/500 lost zero point
    I have the same thing with an older machine. I am going through the Meldas 60 OPerations manual for zero-setting and the machine will not move. When we change parameter #2049 (x and Z) to 0 0 the machine will move around fine. When I change it back to 2 , 2 for Marked Point Alignment Method nothing will move. I have aligned the marked points and went into the ABS. POSITION SET procedure. I set #0 to 1 and then set #2 to 0.0. THen set #1 to 1 . No movement even when I put big numbers into #2. I can turn it off and back on and repeat the procedure for both x and z. Or only z then Only x. Same results. No movement.
  1. looking for lost parameters for mori-seiki
    By landcfab in forum Machinery Manuals / Brochures
    Last Post: 06-18-2012, 05:23 PM
  2. Mori Seiki NL2000 coding problems
    By bmiller44875 in forum Mori Seiki lathes
    Last Post: 01-30-2011, 06:39 AM
  3. Lost reference point
    By Finnur in forum Uncategorised MetalWorking Machines
    Last Post: 11-23-2009, 10:50 PM
  4. Need Gibb Post for 2008 Mori NL2000/SY500
    By gphodge in forum GibbsCAM
    Last Post: 10-21-2009, 05:51 AM
  5. Mori Seiki NL2000/2500 series the good the bad the ugly
    By victor-arcp in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2009, 02:51 PM
