I can get transform to work...kinda... I can get it to transform the operation once, but not more than once. Also, by changing the number of steps on the translate - between points parameter, it just seems to increment the work offset (which is also the first operation) instead of creating another set of operations. However, the number increments in the operation manager next to the backplot icon (I've associated that number with size of NC file, not sure if that's exactly how it works). So, it looks like the transform is calculating extra operations with each step increase, yet not actually posting them. Also, operation type doesn't organize by operation. It still wants to complete the part before changing origins. Help?
Attachment 218938
