587,916 active members*
3,868 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > More problems, DMC103v tool changer this time
Results 1 to 4 of 4
    May 2005
    122
    Hi Folks,
    I managed to get the machine working, thanks to the help from cncmm but now I have a serious issue. Today, I came in and started the machine, with very low pressure (4bar instead of 6.5). While referencing things went ok, but when I tried to load a tool, the tool changer just flopped to open position and the head tried to come down but there was no tool change. Instead the cycle went into error mode, which is obvious, given that there was too little line pressure.
    Now, after switching on the air pressure, I tried to restart the machine, the tool changer is not zeroing and now the yellow button (on the left of button number 114) is blinking. No reset works. Does anyone know how to get out of this? My machine has a Siemens 810D controller and three software licenses: 1. toolbox, 2. FM-NC/840D/DE system, and 3. Shopmill
    Thanks,
    N
    May 2005
    122
    Re: More problems, DMC103v tool changer this time
    Aaah, should have waited a bit before shooting this one off. I've fixed the issue. cmcmm had sent me a trouble shooting manual in german, google helped me translate it and I followed the procedure to move the changer manually using the following process:
    1. Jog mode
    2. Area switchover
    3. Softkey 7 deckel maho
    4. Softkey 7 manual operation
    5. Softkey 1 tool change
    6. With the keys yellow or violet, the tool changer can be moved. If it doesn't move after poking these,
    7. Ref the axis. And all should work.
    This is what I did... and I've no more tool changer hangup.
    Mar 2007
    64
    Quote Originally Posted by nash View Post
    1. Jog mode
    2. Area switchover
    Sure would be nice if we had that manual in English! !!
    Jun 2015
    3
    SCHAUBLIN 43 CNC Problem
    Hi all,
    Following is the problem with SCHAUBLIN 43 CNC
    Automatic tool changer goes to pick up to tool from the spindle but arm fingers are not closing to clamp the tool so spindle dropping the tool before arm holding
    Hydralic oil not draining out from the arm resulting in not closing of arm jaws
    Anyone had the similar problem ?
  1. tool changer problems
    By M3 Machine in forum Community Club House
    Last Post: 06-08-2013, 08:43 PM
  2. TOOL CHANGER WASTED TIME
    By cncbeastmaster in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2013, 04:03 AM
  3. Tool Changer Problems
    By zsinclair in forum Haas Mills
    Last Post: 05-18-2011, 08:56 PM
  4. Time delay command for tool changer?
    By greeder88 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-15-2009, 10:46 AM
  5. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
