586,523 active members*
3,332 visitors online*
IndustryArena Forum: Momus Design CNC plans
Page 3 of 13 12345
Threads 41 to 60 of 248
Discuss Momus Design CNC plans here!
  1. Sticky Thread Sticky: Modification for easier tramming
    Started by momus_cnc, 07-10-2012 02:17 AM
    08-16-2015, 01:06 AM Go to last post
  1. Stack of Momus Build Questions
    Started by Segue, 10-13-2013 10:06 PM
    08-30-2014, 08:43 PM Go to last post
  2. R_garza Build Thread
    Started by R_garza, 05-12-2011 06:09 AM
    3 Pages
    1 2 3
    08-03-2014, 06:49 PM Go to last post
    07-11-2014, 08:23 AM Go to last post
  3. My "Kind of" Momus
    Started by DY123, 02-14-2014 11:11 PM
    2 Pages
    1 2
    06-27-2014, 06:05 AM Go to last post
  4. Alternative Suppliers for Canadian Builders
    Started by Mattlockhart, 04-24-2014 02:07 AM
    backlash, bolts, build, buy, buying, canada, cost, costs, hardware, lead screw, lead screws, metal, metal parts, nut, nuts, online, parts, pricing, screw, screws, shipping, sourcing, star, start, stock
    04-24-2014, 02:57 PM Go to last post
  5. New Momus Build
    Started by Jkountz, 09-17-2013 01:28 PM
    5 Pages
    1 2 3 4 5
    04-04-2014, 11:24 AM Go to last post
  6. It's Alive ! Momus 2.0 Build
    Started by Cheeto, 08-07-2013 03:08 AM
    2 Pages
    1 2
    03-18-2014, 12:42 AM Go to last post
  7. Anyone want some Momus parts?
    Started by taiden, 11-15-2013 03:42 PM
    03-14-2014, 08:26 AM Go to last post
  8. Bearing
    Started by good-dog, 01-16-2012 02:50 AM
    03-14-2014, 08:22 AM Go to last post
  9. Follow-Up on missing steps.
    Started by jerrywi, 02-22-2014 05:38 PM
    axis, belts, cnc, cut, cutting, driver, gantry, gecko, holding, load, mac, mach, mach3, manual, missing, motor, motor tuning, price, problem, program, pulley, pulse, steps, torque, tuning
    02-25-2014, 04:05 PM Go to last post
  10. My MOMUS Chipper Shredder
    Started by Levictus, 01-14-2014 08:08 AM
    2 Pages
    1 2
    02-24-2014, 03:35 AM Go to last post
  11. Cracked Y-Axis Bearing
    Started by Mac.CNC, 02-13-2014 06:34 AM
    02-22-2014, 12:20 AM Go to last post
  12. Momus Losing Steps/Position
    Started by Jkountz, 02-18-2014 11:33 PM
    02-19-2014, 04:05 AM Go to last post
  13. CNC not cutting to scale ?
    Started by fastpcuser, 01-13-2014 02:11 AM
    2 Pages
    1 2
    02-10-2014, 11:28 AM Go to last post
  14. Tuning motor settings in Mach3 on metric Momus
    Started by mhalstead, 02-05-2014 11:12 AM
    acceleration, ballscrew, belts, driver, eps, g54, g540, gecko, gecko g540, mach, mach3, metric, micro, motor, motor tuning, pitch, pulley, settings, stepping, steps, teeth, tuning, units, velocity, verify
    02-05-2014, 11:12 AM Go to last post
    01-22-2014, 01:39 AM Go to last post
  15. Lining the inside of a Momus
    Started by Jkountz, 01-17-2014 06:52 PM
    cnc, cnc machine, coating, contact, coolant, find, general, insert, inside, long, machine, membrane, moisture, momus, needed, post, pro, problems, question, removable, reset, return, surface, time, type
    01-18-2014, 04:23 AM Go to last post
  16. Building another machine
    Started by fastpcuser, 07-26-2013 05:22 AM
    4 Pages
    1 2 3 4
    01-17-2014, 03:57 AM Go to last post
    01-13-2014, 07:45 PM Go to last post
  17. Where are you located?
    Started by ref772, 02-02-2012 09:38 PM
    3 Pages
    1 2 3
    01-13-2014, 05:10 PM Go to last post
Page 3 of 13 12345
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
