Attachment 239590
With the continuous improvement of the rapid development of laser technology and production processes, laser cutting as a precision cutting equipment is quietly instead of the traditional punching equipment, in the face of dazzling, heading complicated laser cutting machine model, and boasting some businesses random , laser cutting machine buyers even more confused. Laborers - level enterprise technical centers and the National Center for Laser Processing and National Key Laboratory of Laser Technology Laser Processing Engineering Research Farleylaserlab rely, from a professional point of view, make the following observations on modern laser cutting machine selection:
The first,from now on laser cutting machine laser applications and user technical requirements, the laser cutting machine is undoubtedly the future direction of development of high-power, large-format, high efficiency, a molding, high intelligence. WALC wide format series locomotive industry, heavy industry, the universal application gives users a high quality and efficient productivity; CONTOUR series of high-speed high-precision cutting machine engineering machinery, high value-added products are widely used in industry; as external processing industry, ultra-cost-effective laser cutting machine cantilever Minter is the best choice,the prospect of laser cutters for sale is very good.
The second,fiber laser with robots in flexible manufacturing systems and high-status automotive industry supporting industry a long time, used to be monopolized by foreign builders in recent years due to the financial crisis and rising auto industry production technology, especially in the domestic high-end laser technology manufacturers, many foreign car brands and national brands have high-value domestic high-end equipment, the foreign share of ultra-high price arrogant and mysterious veil has been lifted, torn, laser welding, car bumpers, doors, columns and other robots in flexible cutting machine, laser welding car bumpers, car exhaust pipe welding line systems, automotive automatic gearshift sets of laser cutting equipment, etc., at the user site 24 hours a stable and efficient production.
The third,laser cutting machine selection factors to consider a lot, in addition to considering the current maximum workpiece size, material, you need to cut the size of the maximum thickness and format of raw materials, the more the need to consider the future direction of development, for example, products made the maximum size of the workpiece to be machined after technical modifications, the format provided by the steel market for the material of which most of their products and material, loading and unloading time and so on. Laser cutting machine is a high input high output, modern equipment, time-saving one minute every possible means to earn a ten yuan. Points surrounding the status quo is also a laser cutting machine laser cutting machine buyers must concern the fierce market competition must avoid homogenization of competition.
The fourth,railway locomotive industry, heavy industry, construction machinery and other industries, although the contour to be machined parts are not too complicated, because the process is subject to the constraints of the original means of purchase is basically common market 3015. Future enhancements processing capacity and efficiency, it is recommended to use WALC Germany rofin DC040 series with the laser generator, format generally 3-4.5 meters wide and 6-30 meters in length, this one-time processing can be achieved Plate, saving time and material . When comparing workpiece thickness exceeds 20mm long, WALC and precision plasma (with a thickness of more than 45mm above plus flame cutting) rail cutting equipment is the best choice for processing 3-50mm thick steel plate even more, simultaneously cutting the material, thickness board while cutting will greatly improve processing efficiency. For some small parts, high-speed and high-precision CONTOUR4020 6020 series is the best choice,the prospect of laser cutting machine for sale is very good.
The fifth,military, heavy-duty vehicles, buses, and other large equipment industry is characterized by relatively stable object processing, high quality and efficiency is more important requirements, it is recommended to use CONTOUR DM3015, 4020,6020 is the best choice, conditions permitting, maglev driven CONTOUR LM3015 and 4020 even better.
CONTOUR series laser cutting machine are all closed-loop control, single-axis drive speeds are more than 100m/min, is a real high-speed high-precision precision cutting equipment.
The sixth,saw the industry recommended profile3015 with rotary table, the current domestic manufacturers bigger blade cutting the body more than 95% are Division I profile3015 with rotary table apparatus. Saw industry basically 24 hours uninterrupted production, taking into account the higher level of security and cost factors of production at night, it is recommended to use rofin DC025 and DC030 lasers. Profile3015 with the rotation axis of another large user market is the oil sieve slit pipe industry.
The seventh,MINTER popularity as a sophisticated device applications of laser cutting machines, more suitable for outside processing industry, its strong cutting capacity steel is 20mm, steel 10mm, 8mm aluminum and high feed tripartite openness and accessibility, as well as its cost is undoubtedly the best choice for outside processing industry, steel industry,the prospect of laser cutter machine for sale is very good.
The eighth,profile6015 a positioning process technologies such as optical laser cutting machine is the best choice for the automotive industry special processing, military, high-end external processing enterprises,environmental protection equipment industry.
