587,487 active members*
3,428 visitors online*
Results 1 to 4 of 4
    May 2007
    781
    Missing Window
    I am using a laptop that I plug a second monitor into when I am at home.
    At some point the "Selected Entity Info" window must have found it's way off the screen, it is not showing up on either monitor.
    Any way to reset the position?
    Jan 2007
    333
    Can you disable second monitor thru laptop settings?
    765
    Andre',
    The attached file contains registry settings that will reset the entity info window position. Close NCPlot, unzip and double-click the attached file and confirm that you want to add the settings. This file is for v2.05, if you have a different version let me know and I'll get you a reg file for it.
    Thanks,
    Scott
    Attached Files Attached Files
    May 2007
    781
    Quote Originally Posted by bborb View Post
    Yes, but still not visable.
    MetLHead:
    Thanks that will save me from having to dig around the the registry.
  1. Changing view in Tk Window?
    By Zathras in forum LinuxCNC (formerly EMC2)
    Last Post: 07-04-2008, 06:12 AM
  2. How can I drill a 2" hole through a window?
    By garagefela in forum Glass, Plastic and Stone
    Last Post: 01-30-2007, 02:00 AM
  3. Window cleaner as cutting fluid
    By voxelman in forum MetalWork Discussion
    Last Post: 05-14-2006, 07:03 AM
  4. Jogging window...
    By murphy625 in forum CamSoft Products
    Last Post: 04-06-2005, 12:01 AM
  5. window channel and nylon
    By ShayArnett in forum DIY CNC Router Table Machines
    Last Post: 12-26-2004, 05:36 AM
