New to the world of cnc and looking for something to cut out side plates for fishing reels. The biggest I will do is 8" round.Would a mill be better or a table router? I know it is going to take some time for me to learn how to use one with all the G codes. Here is some info on one I saw on Ebay. Does anyone think I would be good for what I need. Also any one know of a good band saw that will cut up to 8" solid round aluminum? Thanks for any help.
Item Specifics - Mills, Milling-Type Machines
Type: CNC, Vertical X-Axis Travel Bed: Less than 10''
Make: PROXXON Y-Axis Travel Bed: Less than 10''
Model: PF230 CNC Z-AxisTravel Bed: 10'' - 15''
Highest Spindle Speed (RPM): 2501 - 3000
Visit my eBay Store: B.P.SALES&CUSTOMCNC
THIS IS THE PF230 CNC MILL THE UNIT WILL BE FULLY LOADED WITH EVERY OPTION UNLIKE THE COMPETITION WHO ONLY SEND YOU THE BASE MACHINE FOR $3000.00 . MY UNIT COMES STANDARD WITH MINEBEA NEMA 23 MOTORS ,DELEGRANGE TECHNOLOGY 10 AMP 4 AXIS CNC CONTROL BOARD, MACH 3 MILL PROGRAM AND A WEB SIGHT TO HELP YOU SET UP YOUR MACHINE IN 30 MIN WITH STEP BY STEP PICS OF THE WAY YOUR SCREEN SHOULD LOOK ,25 PIN COMPUTER CABLE , POWER SUPPLY IN A METAL BOX WITH OPTIONAL WOOD BOX FOR $25.00 MORE ,ENDMILLS, DIVIDING ATTACHMENT , 4 JAW CHUCK ,FINE FEED , V BLOCKS 2 SETS OF CLAMPS, GEAR CUTTER ARBOR WITH ALL CUTTERS, CENTER DRILLS , DRILL CHUCK , 2 SETS OF COLLETS , DRILL AND TAP SET , FULL WARRANTY ********PLUS A MACHINE THAT ACTUALLY WORKS AND DOES WHAT IT SAIS IT CAN DO !!! THIS MACHINE CAME IN ON FRIDAY AND THE MOTORS AND MOUNTS HAVE BEEN INSTALLED ITS TIME FOR THE WIRING !-------AND UNLIKE THE COMPETITION YOU GET TO KEEP YOUR MANUAL HAND WHEELS SO IF YOU DONT NEED THE CNC SETUP YOU CAN STILL USE THE MACHINE BUYER PAYS ALL SHIPPNG COST UNIT WAYS ABOUT 50 POUNDS.
SPECS TABLE: X= 10 5/8 Y= 3 5/32 TSLOTTS= 15/32X15/64X13/64
TABLE TRAVEL:X=7" Y=3" Z=11"
MACHINE IS 6 SPEED VIA BELT DRIVE 280,550,870,1250,1700,2500 RPM
THIS IS THE PROTOTYPE ,YOUR MACHINE WILL BE CUSTOM BUILT AND SENT WITH ALL THE OPTIONS DESCRIBED. THE BASE PRICE FOR THE MANUAL MACHINE IS $899.00 WITH 3 COLLETS . I CAN SELL THESE ALSO I AM A DEALER FOR PROXXON SO YOU WILL SEE ALOT OF THERE PRODUCTS LISTED FOR A BETTER PRICE THAN ANYBODY ELSE CAN OFFER !!!! PD230 CNC LATHE COMING SOON ADD ME TO YOUR FAVORITES AND WATCH .
CUSTOM CNC MACHINES --- I WILL BE BUILDING ALL KINDS OF EQUIPMENT IN THE FUTURE SO MAKE SURE YOU STAY ON THE LOOKOUT........................................... .................................................. ....
________________________________________
On Apr-08-06 at 21:31:04 PDT, seller added the following information:
PROXXON CNC MILL
