I've been experimenting with dry machining some of our aluminum parts and have had a fair amount of success with half inch cutters, but have not been able to achieve a decent finish with anything smaller.
This is what a profile cut looks like with a 1/4" .030r carbide two flute.
The cutter was out of the holder about 3/4 of an inch and that wall that I was cutting is about half an inch tall. 7500rpm 50ipm I had already roughed it with a 1/2" .090r and left .020 to be cut which I did in Zsteps of .025 with two XY finish passes.
This is the whole setup:
The clamp is just holding a stop block.
I'd appreciate any advice you might have on how to improve my finishes. As I've said we do run coolant on our machines also. But it's water based (Tri-Cool) and wreaks havoc on the whole machine. We decided on the Tri-Cool because we also cut a lot of foam and plastic which would become unpaintable if it gets impregnated with anything oilbased.
I appreciate any and all input.
thanks
Kit Headley
Modelmaker
