Hi
I have searched around for similar topics, have found some, but they haven't been able to help solve my problem. Besides that I hope it is to right forum to ask in, if not I apologize.
My setup is a DIY CNC, designing and making g-code with Fusion 360 and control the CNC with Mach3. I am a newbie with all this stuff, but have so far learned a lot, and have really enjoyed the journey in this cnc hobby world, though it is a bit frustrated at times, when things doesn't work out as they should. But it is a learning process.
I try to mill a hole in wood with a diameter of 18mm, it is milled at app. 16mm. It is like the machine leaves a bit of stock, but I have checked that mark off in Fusion 360. I have tried to mill with a 6mm end mill and a 8mm end mill, it doesn't work with none of them. I use the 2d Pocket cam function in Fusion 360 with multiple depths. Found something about compensation, and something about a possibility to change tool in Mach3, but as I have understood and tried from this info, it doesn't work too.
Hope someone can help me out here, thank you a lot!
