587,535 active members*
2,538 visitors online*
    Mar 2004
    5
    Microstepping question
    Has anyone read the article "Microstepping Myths" at http://www.machinedesign.com/ASP/str...tedArticle.asp
    From the article "...The table shows the significant impact of the incremental torque/microstep as a function of the number of microsteps/full step."
    Does anyone here using microstepping controllers for their CNC machine see this torque/microstep relationship ?
    Regards, Tim.
    Apr 2003
    89
    Cool site!
    Jan 2004
    71
    Re: Microstepping question
    Hi Tim,
    Yes you will loose some torque, but the benefits from the smoother movements and the reduce resonance problem more than made up for it. We were actually loosing steps with full and half steps due the motor resonating. At a certain resonance frequency torque drops significantly, and this happened to be near the speed we were operating at. With the micro stepping boards, resonance problem were significantly reduced. It was reassuring to know that the motors performed more consistently.
    We have no problem with miss steps and have plenty of torque for the milling machine. We use 8 micro steps, but you can use less with our design, even go back to full or half steps. No point in using more than 8 micro steps since the stepper motors don't really resolve much more.
    Kin Fong
    http://www.embeddedtronics.com/
    Originally posted by TimW
    Regards, Tim.
    Robotics, CNC, and Controllers
  1. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  2. DIY Electronics question
    By CNC Darren in forum Hobbycnc (Products)
    Last Post: 02-14-2005, 04:32 AM
  3. Question about power supplies
    By dowling177 in forum CNC Machine Related Electronics
    Last Post: 01-28-2005, 02:01 PM
  4. Lathe to CNC - Microstepping
    By creative_mind in forum CNC Machine Related Electronics
    Last Post: 04-13-2004, 04:56 AM
  5. Just a question about plunge milling.
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-29-2004, 03:36 AM
