587,482 active members*
3,586 visitors online*
Results 1 to 8 of 8
    Sep 2007
    13
    metric vs. imperial acme screws?
    I live in australia and I plan to mill things that have been designed with a metric system in mind.
    For my CNC router...would getting metric acme screws be preferable over imperial ones? What are the disadvantages of using imperial acme screws if every part i plan to mill is in metric?
    I say this because i am able to source imperial acme screws quite cheaply, but metric ones are almost 2x more.
    Mar 2007
    85
    Quote Originally Posted by carsonau View Post
    Hi, Welcome to the site.
    Regarding your question, I am also in the same situation. What I have found is that finding components for metric acme screws is going to be a problem. (Most of the anti-backlash units are made for imperial acme screws)
    Hope this helps a bit.
    Apr 2003
    470
    It doesn't really matter a whole lot when your leadscrews are imperial and your parts are metric. We make metric parts in the states on imperial machines all the time... A 1/2 Dia screw with a 10 turn per inch lead, it's in metric terms a 12.7mm 10 turn per 25.4mm screw. If one turn of the lead screw moves the axis .1 inch then the same screw moves the axis 2.54 mm. It's not nice round numbers in Metric terms but once you have your machine set up to use metric units you don't have to think about whether or not you have imperial lead screws or not.
    Nathan
    May 2006
    1469
    G'day Carsonau and welcome to the forum.
    What Anoel says is correct. Don't be concerned about it. Use the imperial screws.
    I have a small mill with metric screws and steps per mm are 400. On my router steps per mm are 106.482364.
    Not a nice round number but in use it makes no practical difference at all.
    Where are you up to with your design and build?
    Keep us posted and make good use of the wealth of knowledge and experience to be found on this forum.
    Where in Aus. are you?
    Greg
    Sep 2007
    13
    I am in brisbane! I am just in the planning stages of my "build". I have already ordered a 3-axis kit from hobbycnc.com
    I am thinking of a design similar to a Joes cnc. For the next two weeks I have access to a Roland CNC Router (450mm x 720mm), so i plan to route my MDF (from bunnings) in the next two weeks. Getting everything together after that could take much longer... :P
    Mar 2007
    85
    Hi Carsonau,
    Do you mind sharing you source for Acme screws. I live a few degrees south of you and can't get a proper supplier of acme screws.
    thanks.
    Apr 2007
    67
    Have a look at this site. I got some metric leadscrews from them.
    http://www.tea.net.au/
    T.E.A. Transmissions Pty Ltd Australia
    Phone: (07) 4129 2533
    Fax: (07) 4129 2437
    Email: [email protected]
    Save yourself the hassle and go straight to a proper ballscrew like these http://www.homeshopcnc.com/page3.html
    Money well spent I.M.O.
    Mar 2007
    85
    Quote Originally Posted by Dingo745 View Post
    Fax: (07) 4129 2437
    Thanks, I will give them a ring.
    I am busy with a plasma table so ball screws is not a good option with all the microscopic dust the cutting process produces.
  1. Metric or Imperial Ball Screws
    By chris1407 in forum Australia, New Zealand Club House
    Last Post: 08-07-2007, 11:59 PM
  2. Converting from metric to imperial
    By Pharkas in forum Mastercam
    Last Post: 05-04-2007, 04:46 PM
  3. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  4. Metric mm or Imperial inches? Please help.
    By alexccmeister in forum Benchtop Machines
    Last Post: 02-22-2007, 03:19 AM
  5. Imperial ACME thread in UK?
    By bigz1 in forum European Club House
    Last Post: 11-04-2006, 11:11 AM
