587,790 active members*
3,335 visitors online*
Thread: Mesa 5i25
Results 1 to 8 of 8
    Nov 2005
    111
    Mesa 5i25
    Hi ,
    does someone use a Mesa 5i25 with a 7i77 or 7i76 ? Is it possible without problems ?
    Many thanks for every answer
    Hans
    Sep 2008
    229
    Quote Originally Posted by Holzwurm56 View Post
    Hi ,
    Yes both work fine, but you do need the 2.5 version of LinuxCNC.
    If you don't already have that then the easiest way is to install 2.4.x from the LiveCD and then upgrade using the pre-packaged debs from the buildbot.
    instructions on how to do this are at LinuxCNC buildbot
    Nov 2005
    111
    Hi andypugh,
    I upgrade to Linuxcnc 2.5 , but in the configuration startmenu or in pncconf I doesnt find the 5i25 .
    In what kind of way the 5i25 can be installed ?
    Hans
    Sep 2008
    229
    The quickest way for me to describe (but not the easiest for you) is:
    Start one of the other Mesa configs, such as a 5i23 one.
    It will make a copy of the config in your linuxcnc folder.
    It will fail to start. That is expected.
    Then hand-edit the INI and HAL files
    Remove the CONFIG string from the INI file (or change it if you know what you need, edit it to suit). Note that the 5i25 does not use any firmware, so that, at least needs to be removed from the INI file CONFIG string.
    Edit any mention of 5i20 in the INI or HAL to say 5i25.
    Start linuxcnc from the command line (just type linuxcnc). choose the config you just edited, watch the error messages scroll past, and try to fix them one by one.
    If you can wait a few days, I can possibly help more when I am back at my own computer.
    Sep 2008
    229
    If you say which combination you have I can probably find a pre-built sample configuration.
    Jan 2006
    20
    I have recently implemented a 5i25 & 7i76 setup. I followed the instructions at LinuxCNC Documentation Wiki: UpdatingTo2.5, it works great. There is a thread on the card at 5i25 - 7i76 support testers wanted - LinuxCNC Support Forum
    Stan
    Nov 2005
    111
    Hi ,
    I have Bridgeport 3 axis milling machine , since a long time I want to built in a newer controller . Now the old controller is defect and I must change the controller . I want to use a 5i25 with 7i77 , both I have orderd and hope I am able to make the machine functionally . At first I want to try andypugh's way .
    Many questions are following.
    Hans
    Sep 2008
    229
    You might find you get faster and better answers on the LinuxCNC forums:
    Driver Boards - LinuxCNC Support Forum
  1. EMC and Mesa
    By Holzwurm56 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-26-2011, 05:09 PM
  2. Mesa de agua
    By goyoasturias in forum Spanish
    Last Post: 01-09-2009, 08:06 PM
  3. Mesa, AZ
    By john matthews in forum Mentors & Apprentice Locator
    Last Post: 08-24-2008, 07:48 PM
  4. Mesa de coodenadas.
    By Mentus in forum Spanish
    Last Post: 12-11-2007, 11:34 PM
  5. Mesa 5i20 and EMC
    By daedalus in forum LinuxCNC (formerly EMC2)
    Last Post: 06-27-2007, 08:19 PM
