587,594 active members*
4,177 visitors online*
Results 1 to 4 of 4
    Dec 2005
    3
    MAZAK QT10 T-2
    i BOUGHT A QT10 T-2 1986 year model it had the frse out of it i sent had rebuilt i installed it powerd machine up hyd pump does not come on when i power up controller also machine sat for 5 years so with that being said
    it has some error codes
    131 illega param m1-m12
    150 illeagal pocket
    442 chuck barrier malfunction
    443 tailstock barrier malfunction
    ? 1 backup battery wipe out memory
    ? 2 were and how do i load param back into machine
    and were do i get param
    check my picture out
    any help would be great full thanks Steven
    Dec 2003
    24220
    It looks as you have definitely lost parameters, the memory has to be cleared then the parameters re-entered.
    Any time you see an asterisk on the screen, this is a give away.
    You may have to contact Mazak with the model and serial# to obtain the originals.
    Hydraulics will not come on until this is done.
    As a last resort, they can be loaded manually when you get them.
    Al.
    Albert E.
    Jan 2008
    65
    Quote Originally Posted by STEVEN911 View Post
    150 illeagal pocket
    You DEFINITLY lost parameters and you will most likely have to re-initializyour control. Look in your electrical cabinet on one of the doors to see of you have a hard copy of your parameters.
    Mar 2004
    761
    Made in 1986? You should also replace the controls batteries.
    Wayne Hill
  1. MAZAK QT10 & BAR PULLER
    By paul wilcox in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2017, 12:47 PM
  2. qt10 spindle moves back and forth
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-04-2008, 01:54 PM
  3. problem with mazak qt10 t1
    By diz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-12-2007, 05:24 PM
  4. Mazatrol t1 qt10 cpu problem
    Last Post: 10-17-2007, 01:29 PM
  5. Forklift ran into our little QT10..help!
    Last Post: 07-19-2007, 02:15 PM
