587,858 active members*
3,515 visitors online*
Results 1 to 8 of 8
    Mar 2008
    2
    Unhappy Mazak Mazatrol Control M1 -- Spindle Alarm
    I've bought a old Mazak VQC 20/50B with Mazatrol M1 Controller with pallet changer.
    I am facing a problem with Machine the Spindle is not functioning it shows Alarm No. 251 (Spindle Driver not functional).
    Spindle drive is Frequol make. In the spindle drive the display shows no. E7 & the spindle is not rotating.
    Can any please suggest, how can we rectify this issue.
    How can i start the machine. Sometime back the machine was running perfectly, but now its constantly giving error for Spindle. Also please suggest how the pallet changing works. Does the pallet change automatically using the program or is it manual.
    This machine menus are in Dutch, is there any way of changing it to english.
    Jan 2008
    65
    sounds like you have a bad spindle drive and yes you can change to english but i dont know how
    Mar 2008
    2
    Thanks bigbobomb,
    But how can i fix the spindle drive?
    Dec 2008
    6
    Post Required wiring diagram VQC 20/50B Mazatrol M1
    Dear Sir,
    How are you. We have same machine VQC 20/50B with Mazatrol M1. we purchase used machine. Unfortunately during shipping electrical cable broken. We have no any wiring diagram and control manual. There for it’s not in working conduction. Can you help us with sending the manual and wiring diagram through email scan copy. I m thankful to you..
    [email protected]
    Nov 2006
    925
    You can download the Freqrol manuals from www.meau.com
    Additionally a search of the Mazak forum here will produce a lot of good info.
    Nov 2008
    3
    Quote Originally Posted by stephen21in View Post
    Thanks bigbobomb,
    We had fixed one, but another is failed.
    Suggest to replace it with a new converter.
    Mar 2005
    59
    What is the manufacturer of that spindle motor ?
    I don´t remember what is E7 error. Sometime ago we have similar bug, spindledrive just doesn´t start.
    Does spindlemotor fan rotate ?
    Juka
    Nov 2008
    3
    E7 NCE NC EMERGENCY STOP
    * Warning which is issued when an emergency stop signal is inputted from the CNC in bus linkage with the M300 series CNC.
    * Warning which is issued when an emergency stop signal is inputted from the outside while the external emergency stop signal is validated with the related parameter being set.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. VQC 20/40B Mazatrol CAM M2 Alarm 22 Help
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2014, 03:52 PM
  3. Mazak, Mazatrol T1
    By valvulin in forum Spanish
    Last Post: 10-10-2008, 06:17 PM
  4. mazak(mazatrol-m1)
    By mohd khalid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-06-2006, 04:47 PM
  5. Mazak H15 with Mazatrol M2
    By Steve_rb in forum DNC Problems and Solutions
    Last Post: 03-19-2004, 01:27 PM
