587,923 active members*
3,592 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak M2 Freqrol Board (SE-CPU2 BN624A471G54) Setting Problem
Results 1 to 4 of 4
    Jul 2007
    55
    Hi All
    I have a Mazak H12 (M2) with Mitsubishi spindle driver (Freqrol Board SE-CPU2 BN624A471G54), it has a board - BN624A471G54 which has some setting problems thus the spindle now can't find the tool changing position. Also the spindle trembling a bit when running.
    Could anyone who has the Mitsubishi spindle driver please take a look of his board (It doesn't need to be exact BN624A471G54) and send me a clean picture to show me the setting? Thank you so much.
    Don
    [email protected]
    Jul 2007
    55
    Hi everything
    Problem already solve. Let me simply explain how it solved.
    It cames out the DIP switches wasn't adjusted right as I expected, and I found out the Mazak/Mitsubishi original parameter for Freqrol Drive FR-SE which will explain all the DIP switches detailly. Guys, who needs a copy please let me know.
    I also have FR-SX and some others.
    Hope it will help YOU.
    Sep 2011
    26
    Hi can you please send me a copy of how to set up dip switches on fr-se drives to [email protected]
    Quote Originally Posted by Donatello Tam View Post
    Hi everything
    Jul 2007
    55
    Re: Mazak M2 Freqrol Board (SE-CPU2 BN624A471G54) Setting Problem
    Quote Originally Posted by beto81 View Post
    Email sent
  1. Mitsubishi FREQROL problem
    By eva_1686 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-11-2020, 04:24 PM
  2. Mazak Freqrol FR-SF Alarm 43
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2013, 11:11 PM
  3. freqrol fr-se problem
    By ferrret3238 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-19-2011, 02:03 PM
  4. need help-mc500v BTR board setting problem
    By flytiger in forum CNC Machine Related Electronics
    Last Post: 04-14-2008, 09:52 AM
  5. Freqrol FR-SX Mazak Mazatrol T4 Quick Slant 20
    By machinist360 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-02-2008, 06:51 PM
