587,890 active members*
2,899 visitors online*
Results 1 to 4 of 4
    Mar 2009
    17
    Mazak 640M control
    Has anyone experienced this problem when trying to load a new program error (memory capacity exceeded) comes up. No other programs in memory. Size doesn't matter. even a 2 line program it will alarm out.
    Apr 2008
    44
    Dear Woody
    Where you put program..?
    Memory, hard disk, or ather..??
    Please check, no of program on memory max 256
    Mar 2009
    17
    It is downloaded directly into the control memory.
    Mar 2009
    109
    Reformat the memory area and try again. Perhaps an initialization is in order if that doesn't solve the problem.
  1. 1999 Mazak FJV-250 with Fusion 640M Control
    By Hastx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-11-2010, 04:42 PM
  2. need script parameter for mazak 410a/640m
    By klmmachine in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-25-2009, 03:57 PM
  3. eia restart problem on mazak nexus 640m mill
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2008, 03:58 PM
  4. mazak 640m circular tornado milling cycle
    By magneto259 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-20-2007, 06:03 PM
  5. need post processor for mazak 640m nexus controller
    By Rcky123 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2007, 08:23 PM
