Hello,
We have had no issues with our router until earlier this week, Thanks southern california edison! . Anyway their high incoming voltage caused the W or z axis servo drive to throw a fault on start up. We corrected the voltage issue, but can't figure out the procedure to remove the fault that is logged in the drive.
There is what I believe to be a drive fault reset button, but no place in the manual does it explain how to do it. Obviously that button can only be active when other things are done to prevent accidental resetting of the drive while in operation.
Any help would really be appareciated,
CN 12 controller
Jon
