587,597 active members*
3,734 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X5 - Ramp on contour
Results 1 to 8 of 8
    Mar 2010
    621
    Been trying to figure out how to ramp on a contour move but am not able to find out how to accomplish.
    I need to be able to control the DOC and when selecting "Ramp" in a contour move it doesn't allow for DOC, it's greyed out.
    Ramping to full depth is not an option here...
    Any help would be appreciated.
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Aug 2012
    63
    Re: Mastercam X5 - Ramp on contour
    your depth will be .016 for one pass of your contour. starts at 0 depth and ramps to your setting.
    Mar 2010
    621
    Ah, ok the ramp depth determines the increment and the linking parameter will set the total depth.
    Thanks for the assist.
    Mar 2010
    621
    It appears that TABS are not allowed with the RAMP process... what gives with that?
    Adam,
    Apr 2003
    3578
    Correct tabs do not work with ramp.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Mar 2010
    621
    Quote Originally Posted by cadcam View Post
    Thanks for the reply.
    Can I ask how others needing tabs and ramping combined are completing the process when a contour is involved?
    Am I attempting to do something that just doesn't need to be done, plunge the bit and move on...
    Adam,
    Apr 2003
    3578
    I have not had a customer ask to be able to do this. but I would ramp it down say to .02 aboe the bottom and then do a 2d contours and turn on the tabes with square points.as one quick easy path.
    Cadcam
    Mar 2010
    621
    Thanks for the guidance.
    Adam,
  1. contour ramp not doing a helix around arcs
    By Michaelt83 in forum Mastercam
    Last Post: 09-27-2016, 08:46 AM
  2. Mastercam Help 2d Contour toolpath
    By Hammax in forum Mastercam
    Last Post: 04-17-2016, 01:26 PM
  3. Ramp/Ramp out Contour help
    By ANorwood in forum Mastercam
    Last Post: 12-22-2012, 08:57 AM
  4. mastercam contour faceted cut
    By fjbart70 in forum Mastercam
    Last Post: 06-28-2011, 09:23 PM
  5. Contour on Surface. Mastercam 9
    By kram941 in forum Mastercam
    Last Post: 06-25-2009, 05:12 PM
