587,348 active members*
5,415 visitors online*
Results 1 to 2 of 2
    Aug 2008
    14
    mastercam posts for camsoft
    has anyone figured out which mastercam post processor works best in cnc lite???
    i thought the standard basic fanuc was the post to use.
    if i set the arc parameter to 2 in the setup menu and use i and j with r in the arcs, it seems to work ok but
    as soon as any helical cuts are made in the z axis the controller locks up with an error.
    i've got a favorite post that i use in mastercam that works in haas , a mach 3 controlled mill, heindenhain, and our fanuc without issue.
    this same post also kicks errors in camsoft..
    i must be missing something (i'm feeling pretty stupid)
    steve
    Mar 2004
    1543
    My son is the mastercam programmer, so I'm only repeating here. He started with a Fanuc 6M post and made a few changes. In the case of arcs, I really like absolute I and J. This is an option in Mcam. The post for my lathe uses R.
    I've never got an Mcam post to run without a couple minor edits. I strip off the junk at the front of the Gcode. And have to change the lines with a T in them. For example Mcam says T1 to go to tool 1. I need M6 T0101.
    I'd suggest working out your arc issue with hand coded Gcodes.
    Set arc to absolute I J
    Try this
    G00 X1 Y0
    G02 X1 Y0 I0 J0
    you should get a circle.
    G00 X1 Y0 Z0
    G02 X1 Y0 Z0.1 I0 J0
    Get a helix?
    Karl
    Now try
  1. MasterCam 5 axis Posts (not free)
    By MrMagooo in forum Post Processors for MC
    Last Post: 11-13-2009, 10:52 PM
  2. Mastercam posts on Mazak
    By 60rock in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-13-2009, 04:00 AM
  3. Mastercam X2 Posts
    By nerfman in forum Post Processors for MC
    Last Post: 07-10-2008, 03:47 AM
  4. BobCAD posts vs. Mastercam posts
    By justCNCit in forum BobCad-Cam
    Last Post: 08-16-2006, 08:17 PM
