587,772 active members*
3,150 visitors online*
Results 1 to 5 of 5
Hybrid View
    Jun 2022
    3
    Unhappy Many dots on Laser Engraved Wood
    Hello Everyone!
    I'm a novice, practically a noob, in doing laser work as I've just started a month ago. I'm still experimenting with all the different settings in cutting and engraving.
    I notice that when it comes to engraving on wood, my engraved pieces seem to be littered with dots (uploaded pictures of my results in this post) instead of being smoothly engraved like what I see in videos online.
    My images are processed via Image R with a DPI of around 300. I'm using Inkscape to generate the Gcode which my laser machine can read. I'm also testing it on normal plywood.
    Does anyone know why this is happening and how I can make my engravings smooth?
    Thanks a lot!
    Apr 2004
    5752
    Re: Many dots on Laser Engraved Wood
    If you're starting with bitmap art, this is to be expected. A bitmap is a series of dots, or pixels; the software has no reason to connect any of them. If you want lines instead of dots, you need to start with vector art, not bitmaps.
    Andrew Werby
    Website
    Jun 2022
    3
    Thanks for your reply and your advice.
    If my aim is to be able to engrave smooth images onto wood using source photos taken via smartphone cameras, is there any way to do it?
    Nov 2008
    643
    Vector art isn’t a real thing. Sure it’s a vector drawing like a DXF outline and art I guess but it won’t allow you to engrave a photo.
    Photos are raster scanned images. They are made up of dots and dashes like a halftone image in a newspaper. The image can be adjusted using software. I’d recommend trying Lightburn.
    Jun 2022
    3
    Thanks for replying and your recommendation.
    I'll play around with the free trial and see where it gets me.
    Cheers!
  1. What kind of file extension for image to be engraved into wood?
    By JohnnyScience in forum DIY CNC Router Table Machines
    Last Post: 06-13-2019, 08:21 AM
  2. Laser setup - Mirrors aligned, getting two dots with pulse and tape on laser head
    By tjandt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-06-2019, 01:44 PM
  3. finishing engraved photos in wood
    By benjamint76 in forum WoodWorking Topics
    Last Post: 01-09-2009, 03:45 PM
