587,657 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Manual Threading with Compound vs CNC without Compound
Results 1 to 6 of 6
    Jan 2006
    16
    I have a question on Manual vs CNC single point threading. As I understand it, in manual threading, the
    Compound is set at an angle of 29.5 degrees. As the thread is cut, successive cuts are made by advancing
    the compound, not the cross slide.
    Since the CNC machines, at least the ones I have seen, do not have a compound, the only way to make the
    next cut is to advance the cross slide.
    So, does a CNC machine actually engage the next thread cut at a variable point in relation to the indexed
    point of rotation, thereby replicating the use of a compound?
    I hope this question makes sense. I can see it in my mind. It's just difficult for me to put into words.
    Feb 2009
    6028
    Big battle over the whole 29.5 deg thing. But yes, cnc have infeed patterns. Some replicate the 29.5, some do a zig zag pattern, some feed straight in. Depends on the thread type you want to cut. It's usually a preparatory code in your threading cycle.
    Dec 2004
    783
    I don't know too much about it, but a quick google search revealed that you can use different g codes and sub routines for different styles of cutting threads, some feed in at 29°, but it all depends on what codes are supported by your machine control, and if your using CAM or not.
    Sent from tapatalk
    Jan 2006
    16
    Thanks "underthetire" and "Dylwad." That answers my question.
    Looks like I need to investigate the G and M codes.
    Do you know what the reasoning is behind the 29.5 degrees?
    Dec 2003
    24220
    I would suggest getting a book such as Peter Smid CNC programming.
    The compound infeed the .5 degree difference avoids rubbing of the tool and excessive tool wear.
    G codes are fairly standard and vary as to type of machine, Mill,Lathe, Plasma, EDM etc, M codes are dependent on the MTB and can vary between the same types of machine.
    Al.
    Albert E.
    Jan 2006
    16
    Thanks for the info Al. I'll checkout the book.
  1. Lapping compound?
    By zamazz in forum Benchtop Machines
    Last Post: 04-29-2013, 04:34 PM
  2. 1720 XMTC Manual and Compound Slide
    By grahasp in forum Shopmaster/Shoptask
    Last Post: 08-07-2010, 06:57 PM
  3. compound infeed for threading
    By g30u0w0 in forum Daewoo/Doosan
    Last Post: 02-24-2008, 06:05 PM
  4. what is a compound?
    By diluded000 in forum MetalWork Discussion
    Last Post: 07-31-2007, 04:35 PM
  5. Enco Compound Slide Milling & Compound Drilling Table
    By 7ofclubs in forum DIY CNC Router Table Machines
    Last Post: 12-24-2006, 05:43 AM
