Hi Wrecker, that's a bit of an optical illusion I'm afraid.
When I dismantled my quill I machined a pair of set screw holes on each side.
Hmm, that's difficult to explain- hopefully this view from underneath the quill casting will explain.
Into these holes go set screws with lock nuts to prevent them coming undone. On the inside these screws have little bronze slippers that push on the quill- all forcing it towards the right (or end of the casting) and in the same direction as the clamp.
The stripe you see on the quill is the witness of the bronze slipper pushing on the surface of the steel.
