586,068 active members*
4,034 visitors online*
IndustryArena Forum > CAM Software > MadCAM > MadCam Toolbar
Results 1 to 18 of 18
    Feb 2012
    17
    MadCam Toolbar
    I installed the newest version of MadCam and Rhino 5.0 to get the current Post processor for my Camaster CNC. The one I had did not work correctly with WinCNC. Everything went smooth with the install. I have all the MadCam commands from the command line but for the life of me I can not get the MadCam Toolbar to show up in Rhino. It is a pain to keep loading from the command line when I know the icons better. I have read the MadCam help file and followed the instructions many times but no luck. Keeps telling me the toolbar is already loaded. If I use the file/ open to load the toolbar all I get is a smiley face icon.
    Any help would be deeply appreciated.
    Mar 2004
    1661
    Re: MadCam Toolbar
    Go to the menu Tools->Options.. and then Rhino Options->Toolbars.
    Do you have a madCAM menu specified there? You should have at least default and madCAM.
    If not, right click under default and choose new. Select the file found under C:\Users\[your username]\AppData\Roaming\5XCNC\madCAM\5.0\UI\madCAM.rui and hit OK.
    Please note that the folder AppData is hidden but if you specify it manually it will work.
    If you don't have that file there was probably an issue with admin rights that caused the installation to fail.
    Feb 2012
    17
    Re: MadCam Toolbar
    No luck. It just puts a smiley icon on rhino screen. No toolbar icons. I uninstalled Rhino 5 and MadCam 5 and re-installed both. When I started Rhino it said it found MadCam plugin. When I follow your instructions default & madcam do appear. When I click on Madcam and select it then click install it says that Madcam.rui is already installed. If I click on new & go to
    C:\Users\[your username]\AppData\Roaming\5XCNC\madCAM\5.0\UI\madCAM.rui and click OK it just puts that smiley icon on Rhino Not sure what else to try.
    Feb 2012
    17
    Re: MadCam Toolbar
    I was hoping Joakim would see this and post a solution.
    Feb 2012
    17
    Re: MadCam Toolbar
    There has to be someone that is using the latest versions of MadCam & Rhino that can be of help. It's not a rare combination. Probably something dumb on my part.
    Feb 2012
    17
    Re: MadCam Toolbar
    Bump
    Apr 2003
    1357
    Re: MadCam Toolbar
    Quote Originally Posted by Bobcef View Post
    What do you mean "click install"? If you have a madCAM entry shown as an existing toolbar you should be able to just pick the checkbox below to show toolbars.
    If you have an install option available, I have a feeling you are in the wrong spot.
    Dan
    Feb 2012
    17
    Re: MadCam Toolbar
    Dan I was trying to remove MadCam from the list and reloading it. I am in the right spot and when I pick the check box below no list of icons appears. If I then click OK I get a smiley icon. Are you using the newest versions of Rhino & Madcam? I had the icons before I upgraded. The post processor was not working correctly for WINCNC in the older version.
    Mar 2004
    1661
    Re: MadCam Toolbar
    When you reinstall you have to delete the hidden appdata folder as well to make sure it's a clean setup. Delete both the MadCAM and the Rhino folders.
    Feb 2012
    17
    Re: MadCam Toolbar
    OK will try that next. Thanks for the replies.
    Feb 2012
    17
    Re: MadCam Toolbar
    Well thanks to Joakim the issue is resolved. He e-mailed me a copy of madcam.rui file then called me long distance and walked me thru. He had me save it to my username/documents directory where I can easily find it.
    Viola in less than 2 minutes all was well. I thank I was loading the file from a older version of MadCam. Got rid of all the other madCam.rui files. Now that's customer service at it's finest.
    Thank you again Joekim.
    Apr 2003
    1357
    Re: MadCam Toolbar
    Glad to hear it's resolved.
    Feb 2012
    17
    Re: MadCam Toolbar
    Thanks Dan
    Apr 2015
    32
    Re: MadCam Toolbar
    I had the same smiley problem exactly as described by Bobcef (I use Windows 7 x64). Had to delete that 5XCNC folder each time before upgrading. One time it lost all the cutters and post folders. Weird.
    Quote Originally Posted by svenakela View Post
    Feb 2012
    17
    Re: MadCam Toolbar
    Don't know why there is such a convoluted path. I moved my file to my documents directory where I can easily find it.
    Apr 2015
    32
    Re: MadCam Toolbar
    How did you move those default locations (I assume after install)? I did not find anything in the options.
    Feb 2012
    17
    Re: MadCam Toolbar
    Yes long after install.
    Apr 2015
    32
    Re: MadCam Toolbar
    Thx. For those interested it's through the MadCAM options not the Rhino options.
  1. bobcad toolbar
    By bankshot in forum Uncategorised CAD Discussion
    Last Post: 03-28-2014, 12:04 AM
  2. Gray toolbar ???
    By MachineManiac in forum CamWorks
    Last Post: 04-28-2012, 02:08 PM
  3. Command Toolbar? etc.
    By cjdavis618 in forum Visual Mill
    Last Post: 11-23-2010, 02:11 AM
