587,497 active members*
4,692 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Machining Sterling Silver
Results 1 to 7 of 7
    Jul 2006
    53
    Question Machining Sterling Silver
    anyone machined sterling silver before, i'm looking for speeds and feeds to start with,,
    i'm going to be using 1/2 endmill for roughing, probably diamond coated, and 1/4 ball for finish, also diamond coated,
    i'll look for your input, thanks
    Jan 2008
    89
    Can I have the chips?.................I have turned it before but not milled it. If I had to point you in a direction, it is a little like 6063 Alum. soft and gummy. I think that if you treat it that way you'll be good. I'm assuming that you are not milling huge amounts of it and if you are, I definetly want the scrap! Although when you think about it, there are engineered plastics out there that dwarf Gold in cost by weight.
    Sep 2007
    200
    what are you doing anyway?
    please could you look into wax investment casting and save the planet!
    Jul 2006
    53
    Quote Originally Posted by sti2011 View Post
    lol, i know, we are going to put in some fine screen mesh, to catch as much as possible, thanks for your info thou, that's what i was figuring, i was going to cut it like 6061 maybe 10% - 20% slower
    Jul 2006
    53
    Cool
    Quote Originally Posted by draughted View Post
    i can't say what, it's confidential, but the part is abbout 1" x 1" x 12.25"
    can't cast it, too much fine detail on it, they tried, i machined it out of alum and stailess before, so they can see the diffrence between cast and machine,
    and its huge,
    save which planet, mars ???????????? lol
    Apr 2004
    5749
    I doubt the diamond coating will help much
    That's mostly used for cutting abrasive materials like graphite and fiberglass, which wear down the tooling. Sterling mills a lot like aluminum - it's "grabby", but it's a bit harder. I'd experiment with a copper rod to start with; if your speeds and feeds work on copper, they'll work on silver. A cobalt-steel tool will be sharper and less brittle than diamond-coated carbide, not to mention cheaper.
    But I also agree with the folks who told you to cast it, not try to carve it out of a solid rod. If you mill it out of wax rod, you can pull a rubber mold from that which will transfer all your detail. Then you can cast a hollow wax, which will cast better than a solid one, while saving a lot of $17/oz silver. Just trying to recycle all that silver swarf is going to be more hassle than not spraying it all over in the first place...
    Andrew Werby
    www.computersculpture.com
    Jul 2006
    53
    thanks for all the infor form you guys, i don't know y the customer dosent want to have it casted, better for my company i guess, lol,
    thanks
  1. silver solder Ti
    By agent141 in forum Welding Brazing Soldering Sealing
    Last Post: 05-26-2008, 02:33 AM
  2. Silver solder
    By temper in forum Australia, New Zealand Club House
    Last Post: 04-02-2008, 11:27 PM
  3. Replies: 0
    Last Post: 12-19-2006, 08:35 PM
  4. silver and deming, what is it?
    By larrymcdade in forum MetalWork Discussion
    Last Post: 10-29-2006, 09:24 PM
  5. Silver solder
    By pminmo in forum Welding Brazing Soldering Sealing
    Last Post: 10-10-2006, 04:22 PM
