587,380 active members*
4,250 visitors online*
Results 1 to 15 of 15
    Mar 2008
    107
    machining black abs plastic
    I have never machined much plastic before and now have a job that will require all .062 and .031 dia mills which I am not used to using.
    The part is only .089 thick and is basicly just a square type cut out with a boss on one side all corners have a .015 radius.
    My question is what to start speeds and feeds at.
    Machine is mini mill 6k spindle I have carbide 2 and 4 flute mills I am thinking
    that the 2 flute tools will be the way to go.
    Thanks Mike
    Sep 2007
    73
    Tool Diameter: .250
    Number of Flutes: 2
    Revolutions per Minute: 6000
    Feedrate: 50 IPM
    Axial Depth per Pass: .089
    Radial Width of Cut: .250
    Power Requirement: 0.3 HP
    This will get you close.
    MC
    Sep 2007
    73
    Sorry I missed the .031 and .062
    .031
    Number of Flutes: 2
    Feedrate: 9.5 IPM
    Axial Depth per Pass: .016
    Radial Width of Cut: .031
    Power Requirement: N/A
    .0625
    Number of Flutes: 2
    Feedrate: 19.2 IPM
    Axial Depth per Pass: 0.031
    Radial Width of Cut: 0.062
    As for drilling get a 135* split point screw machine drill.
    MC
    Mar 2008
    107
    Thank you MC I will start there at least these size tools are fairly cheap.
    Thanks Mike
    Sep 2007
    73
    Anytime. Let me know how you make out.
    MC
    Mar 2009
    107
    MC,
    Are these numbers generated by a machining calculator?
    Sep 2007
    73
    Yes, Granted I don’t ever run plastic but one of the calculators I have does have a wide Varity of plastic. Seeing no one answered his question I figured I would help the best I could. I plugged in his machine specs max rpm and material. It should get him close tweaking may be required.
    MC
    Dec 2008
    319
    What calculator were you using?
    Sep 2007
    73
    X4
    Mar 2008
    638
    Some of our parts are plastic. Delrin, Tecapro, and rydel.
    We like HSS for the finish passes when possible. Lower RPMs than if cutting aluminum (plastic likes to melt). Conventional milling instead of climb makes better finish on walls. Plenty of coolant to flush. Deburr completely on the machine (using spot drill to break all possible edges). Onsrud makes some plastic cutting tools that work well too. (Don't work for them, just bought 4-6 tools)
    Mar 2008
    107
    I have never used a machining calculator do they get you pretty close.
    Are they on the conservative side or the max it will do entill failure.
    Do they tell you basic power needed and does this ussually come in close.
    Finally what one would you recommend and how much does it cost.
    Thank You Mike
    Mar 2009
    107
    Quote Originally Posted by extanker59 View Post
    If your machine produces a better finish when conventional cutting, it is probably due to something being loose.
    Mar 2008
    638
    Our Haas VF-2ss is about a year old and cuts titanium and 17-4ph routinely with no problems. We talked to the supplier of the plastic when we were having issues of "hairs", burrs or poor surface finish. They recommended conventional milling. It works. Plastic is different.
    Jun 2008
    62
    As mentioned before, Onsrud makes an Awesome cutter for this situation. I believe it's the Super O single flute series. Carbide, polished and razor sharp. We would climb cut .125 thick delrin and uhmw and these tools will leave a great finish and no hanging burrs(which uhmw likes to do). You'll still need to break the edge though. HTH
    Sep 2009
    21
    We're running pvc now slot dim. .047+-.005 .125dp 1.5 lg... using .045 e.m. 3000rpm 3ipm z 3 steps...finish 6ipm work's great
  1. machining plastic
    By mmiranda in forum MetalWork Discussion
    Last Post: 07-04-2009, 04:42 PM
  2. Milling Black plastic blocks
    By joguy in forum RFQ Feedback
    Last Post: 11-20-2008, 07:57 PM
  3. Machining Plastic (Centriboard) what bit to use?
    By abelloise in forum Glass, Plastic and Stone
    Last Post: 07-09-2007, 05:01 AM
  4. Machining Plastic (HDPE)
    By Buzz9075 in forum Glass, Plastic and Stone
    Last Post: 07-02-2007, 12:45 AM
