How do I change the machining angle in a surface, rough, pocket cycle for MC9?
I ran the same tool path on a separate drawing and it went in the direction that I wanted. When I imported the same geometry to a new drawing it is going in the opposite direction, and I cant figure out how to change it. The help menu says that you can machine at any angle you want but I don't know how to get to the menu lets you change the setting.
If anyone could throw me a bone I would be forever gratefully and can stop pulling out my hair.
The part is just a half rod with spherical ends, like a tank cut in half length wise. I want to profile it across the width, not end to end. It gives a better finish across the width I believe, at least thats what my tutorial book says. The other 10 of these pockets I cut turned out nice, so I don't want to change a thing.
