After clearing out everything and reloading the NC parameters and what I can find of the PMC parameters. I have tried setting the offsets with a master tool but the machine will not go where it needs to. I use tool 2 ( roughing ) as the master tool and using the Work Shift offset for it. Then using tool geometry for the feed out, the machine goes somewhere completely different.
Reason for clearing machine was a Ram Parity Error on NC side. Have had same error in FAPT for awhile but overlooked it because it would run in NC side. Stopped using FAPT many years ago.
Machine is a Victor TNS-3 with Fanuc 10TF.
Thankful for any help with this.
