587,450 active members*
6,782 visitors online*
Results 1 to 2 of 2
    Feb 2006
    22
    machine sleep mode
    I have a HOWA MZN-500-VC with a Fanuc 18i control. If the machine is not used for a while it automaticsly turns off the hydraulic pressure to the clamping unit. I was wondering if anyone knows of a parameter to disable this function, or if anyone has any other ideas on how to disable.
    Nov 2006
    14
    if you know the output for hyd pressure on please check in the ladder which timer is associated with it and increase the value of the timer
