587,129 active members*
2,951 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Machine set up for 220V/50hz, now on 110V/60Hz, need help
Results 1 to 6 of 6
    Jan 2012
    113
    I just moved a Sieg KX3 cnc into the USA that was initially set up to run on 220v/50hz and USA uses 110V/60 hz. The machine uses 1 KW from what I remember. What do I need to do to power this machine in the USA? Will using 220V/60Hz ruin the machine, do I need a transformer like this Electricity Transformer Adapter Voltage 600W Converter 110v/220v/240v 50HZ/60HZ | eBay but one that will support 1000W? Hope someone can give me some suggestions, I can't use the machine until I figure this out and am urging to play with it
    Jan 2012
    113
    Maybe this will work? 110VAC <-> 220VAC - 1000W Step Up/Down Grounded Transformer for USA & Europe | eBay
    Should I get a 220V outlet installed by an electrician? Would he be able to move it to 50hz somehow? Is it important? Whats my best options here
    Jan 2012
    113
    and if I need to get a transformer should I get a 1000Watt? or get a 2000watt to be safe
    Dec 2003
    24223
    Why not use a 240v 1ph circuit?
    US and Canada have both 120v and 240v 1 phase available.
    For the vast majority of systems the 50/60hz is not going to be an issue.
    Al.
    Albert E.
    Jan 2012
    113
    Yah I think I can solve the voltage issue easily, was more concerned about running it at 60hz, heard it runs hotter. Don't want to mess anything up, already had electric problems with the machine when I first got it, who knows, maybe it was originally made for the US market and they just changed the plug on it.
    Dec 2003
    24223
    Quote Originally Posted by trialanderror View Post
    It depends to some extent what components the machine consists of.
    The inductive reactance of inductive components is higher on 60hz, so in theory the current/heating would be less.
    But the typical make up of a machine such as the Sieg there is going to be very little affected, if anything.
    e.g. switching supplies, DC motor controller etc, even a 1ph induction motor is not going to make much difference, just higher rpm.
    Al.
    Albert E.
  1. Chinese engrave 220 50hz not 110 60hz
    By blairgr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-19-2012, 08:32 AM
  2. 3 wire 220v, no neutral, can i use 110v?
    By Ksoggs in forum Phase Converters
    Last Post: 12-31-2010, 04:55 AM
  3. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  4. Need help with 115v/60hz to 240v/50hz.(newbie)
    By ozzytim in forum CNC Machine Related Electronics
    Last Post: 08-25-2009, 07:47 AM
  5. Got a 60hz chiller instead 50hz need help
    By wickedboysap in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-18-2008, 06:28 AM
