That's right, our mill has arrived! Machine #1064 with 8" fourth axis, TTS tooling system, basic stand, LCD arm, splash guard, and Tormach vise is now snugly installed in its little bay.
The most "fun" part of this arrival was probably the trip from the street back to the shop door. The management is FINALLY having a real sewer pipe installed so that the plumbing doesn't just drain into the Newtown Creek (site of the largest oil spill in an American city ANYWAY...), which has turned the approach into a bit of a war zone. We actually had to put each crate into the back of an F150 pickup truck to get them over the bumps and sand traps...
The bay where our machine now lives is about a foot wider than the machine + base and about 1" taller than the top of the spindle cover when the Z is run all the way up... As you can imagine, this caused the second largest amount of "fun". Thankfully we are rather resourceful (and have a metal shop down the hall), and we got it in.
Everything is now assembled and wired up, and it seems to work just fine. We haven't cut anything with it yet, but everything functions the way it should as far as we can tell.
The one problem we've had so far, which was rather disappointing, has been with the post-processor. We use VisualMill 5 and MecSoft has a Tormach post on their download page. Unfortunately, it is a truly terrible attempt at a post. Many items were implemented poorly, just plain didn't work, or created output which threw errors in Mach3. I've managed to fix them, as far as I can tell, and once I've verified this I'll send it to MecSoft. I ran a test part cutting air, and everything went smoothly. So, if you use VisualMill and are interested in using one of these machines with it, or have a Tormach mill and want to upgrade to a really great CAM program, don't despair!
Anyone else on here located in NYC?
-Jon
