587,380 active members*
3,490 visitors online*
Page 1 of 6 123
Results 1 to 20 of 113
    Aug 2005
    1101
    Mach3 ModIO Handheld Pendant
    Hi All,
    As some will know, I've committed myself to doing a talk at the CNC Convention / BBQ (Melbourne Aus) held on 24th may 2008. Information on this convention can be found at;
    http://www.cnczone.com/forums/showthread.php?t=53559
    The subject of the talk is Modbus, ModIO and Mach3. It will be a fairly basic introduction to Mach3 and Modbus, using the ModIO as the Modbus slave device. For those that don't know what the ModIO is, information can be found at;
    http://homanndesigns.com/store/index...&products_id=4
    The is a lot of interest in affordable handheld pendants for Mach3, so I decided to put together one for the talk. I'm tring to use components that can be easily purchased, and put together without too much effort. Some soldering will be required.
    The enclosure is quite easy to get hold of at Mouser and I will have them in stock next week, The switches and LEDs I have used are my choice but others could be used.
    Attached are some photos of what I've done so far. I created/edited a dxf file for the pendant, used sheetcam http://www.sheetcam.com to convert the dxf to GCode and then used Mach3 to mill it out.
    I plan to white a brain(s) to communicate with the Pendant's ModIO. I haven't decided on the functionality of all the switches and indicators, although the potentiometer on the top right will be for feed rate override and the switch and indicator on the top left will be for spindle control.
    Cheers,
    Peter.
    Attached Thumbnails Attached Thumbnails Enclosure.jpg   MilledEnclosure.jpg   EnclosureAndParts.jpg   ModIOInEnclosure.jpg
    Homann Designs - http://www.homanndesigns.com/store
    Jan 2005
    55
    Hi Peter,
    How does the functionality of this pendant differ from your currently available pendant?
    Thanks,
    Andrey
    Apr 2006
    3498
    very beautiful work u did on plastic
    May 2005
    2502
    Oh boy, this is a thread I am really looking forward to seeing!
    Thanks,
    BW
    Aug 2005
    1101
    Quote Originally Posted by alipavsky View Post
    Hi Peter,
    Thanks,
    Andrey
    Hi Andrey,
    The pendant I currently have available;
    http://homanndesigns.com/store/index...products_id=28
    has the following functionlity,
    • 100ppr Manual Pulse Generator (MPG)
    • 8 position Axis selector Switch
    • 4 position step scale selector.
    • Feed rate override control
    • Cycle Start push Button
    • Cycle Hold Push Button
    • Axis Reference Push Button
    • Spindle On/Off Push Button
    • Enable Push Buttons
    • Emergency Stop Switch
    • LED Status Indicator
    The pendant is very robust, designed for commercial industrial use. This is achieved via the
    • 100ppr MPG,
    • 2 rotary switches,
    • 1 potentiometer,
    • 1 led indicator and
    • 4 push-buttons, plus
    • 2 enable buttons.
    The pendant I'm presenting in this thread will be able to be put together by DIYers. Not every one will want the same configuration as I have done. It is basically to be used as an example of how to go about puttind together your own pendant. This pendant will have;
    • 100 ppr MPG
    • 2 Rotary switches with up to 12 positions each.
    • 1 potentiometer
    • 6 pushbuttons
    • 8 Led indicators
    • 4x20 LCD.
    I haven't decided what functions will be allocated to which switches etc. so don't ask.
    One of the major additions with this pendant is the LCD. It will be able to display axis positions and other data. Also the 3 buttons below the LCD could be "soft" buttons with their function displayed on the LCD.
    Cheers,
    Peter.
    Aug 2005
    1101
    To do the cutting out of the enclosure, I started out with the DXF file for the enclosure;
    http://homanndesigns.com/store/index...products_id=48
    I then edited it using the free CAD tool ProgeCAD 2008 Smart.
    http://www.progecad.com/compra/prodo...2008smart.html
    I deleted all the views other than the one I wanted for Machining. and ended up with the attached drawing PendantDIY.dxf. I then drew the cutouts and holes I needed for all the bits and peices. I used different layers based on the different cutting/drilling operations I would be needing to do in Sheetcam.
    A couple of things I did that may not be clear.
    Firstly I used the view looking into bottom case rather than the top. I did this as it had better detail for parts placement.
    If you look at the drawing, you will see a layer called REF. It contains the 6 holes that screw the 2 halves together. I used this layer in Sheetcam to produce GCode to drill holes at these locations. The purpose of this is to drill locating holes in a mounting fixture on the mill.
    The mounting fixture is just a 1/2 slab of aluminium bolted to the table. Once the 3mm holes were drilled, I loosely screwed 3mm bolts into the mounting bosses in the top 1/2 of the case, then cut the heads off the bolts and located the bolts into the holes I'd drilled on the tooling plate fixture. I then use a couple of clamps to secure the case.
    This gave me a repeatable locating method.
    Cheers,
    Peter
    Attached Files Attached Files
    Aug 2005
    1101
    I used sheetcam to convert the dxf file containing the cut-outs I needed into G-Code. From Sheetcam I generated 4 Gcode files, one for each operation. I did this foor ease of toolchange and to do it step by step.
    If you load the sheetcam job file PendantDIY.job you will notice a couple of things.
    First is I've rotated the drawing by -90 degrees to suit my Taig mills X axis. I've also set the 0,0 origin position to be the bottom left reference hole. That way I just position the toolbit over the holes and zero the axis. Easily repeatible.
    The first GCode file PendantDIYRef.tap drills the reference holes as previously explained.
    The next Gcode file PendantDIYCut, uses a 1/8" mill bit to cut out all the component holes. You can see how using different layers in your dxf cad editor helps Sheetcam in selecting where to cut.
    I then used the Gcode file PendantDIYDrill3_18 to drill the holes for mounting the MPG.
    I then used the Gcode file PendantDIYDrill3_5 to drill the holes for the rotary switch locating tabs.
    I then used the Gcode file PendantDIYDrill4_0 to drill the holes for mounting the LCD.
    In the end thae case came out really nice.
    Attached is a zip of the DXF file, the Sheetcam job and the gcode files.
    Feb 2004
    2337
    12 members and 23 guests in this thread at this moment.
    I think you are onto something good Peter. Keep up the great work.
    I am sure it will also be a hit at the BBQ.
    Regards Benny
    Being outside the square !!!
    Aug 2005
    1101
    Quote Originally Posted by ynneb View Post
    Regards Benny
    Assuming I get it finished in Time.
    Jan 2005
    55
    Quote Originally Posted by phomann View Post
    Cheers,
    Peter.
    Hi Peter,
    I'm just curious how you're going to use this pendant to work the BBQ rotisserie...
    -Andrey-
    Aug 2005
    1101
    Hi Peter,
    -Andrey-
    Well, Once I have the Macropump done, we'll have a new BBQ remote control.
    Jan 2005
    55
    So how would that work out for BTU's per axis?
    Aug 2005
    1101
    Pendant Kit Schematic
    Things have been a bit slow due to having to process orders and a problem with my Pick and place machine.
    For those who are interested, attached is the schematic for the pendant.
    Cheers,
    Peter
    Aug 2005
    1101
    I plan to use a 6 core cable to connect the Pendant to the CNC controller. The connector is shown in the schematic previously posted. As I'm building this for the CNC BBQ demo, I won't be terminating it into the controller but still need a neat way to terminate the cable and get power to the unit and the RS232 signals to Mach.
    My plan is to use a small 2" diecast box. The lid of the box will have the Pendant connector on. I'm doing it this way so that if I want to integrate the pendant into my controller, I can mount the diecast lid only to the front of the controller by the 4 screw mounting holes in the diecast lid. If this is not clear, hopefully I'll have pictures of the finished diecast box in the morning.
    The connectors I plan to use are 6 pole versions of the ones below. A bit of an overkill but they are robust and splash proof.
    I need to drill a hile in the lid to suit the connector and I plan to use the New Fangled wizards to create the G-Code quickly.
    I also need a way to connect the RS232 to the computer, so on one side of the di-cast box I'll mill a DB9 cutout again using the wizard to generate the GCode. On the opposite side of the enclosure, I'll mount a 2.1mm DC power socket for power.
    I haven't had time to mount the EStop button into the pendant, so that will have to wait.
    As I said hopefully I'll have pictures in the morning.
    Cheers,
    Peter.
    Attached Thumbnails Attached Thumbnails 6PinPlug.jpg   6Pinsocket.jpg   EStop.gif   2_1mmJack.gif
    Aug 2005
    1101
    Last night I cut out the small diecast box as shown in the attached pictures. I used the NewFangled Wizards http://www.newfangledsolutions.com to generate the GCode for my Taig Mill.
    Initially, I cit the 0.86" hole in the lid and drilled the mounting holes at 1.2" apart.
    I then Cut out the db-9 connector, again using a wizard, an extremely simple operation (for the wizard). The only problem I encountered was that the wall thickness of the box was about 0.1", so I used the rectangular pocket wizard to cutout a relief to get the wall to the correct thickness.
    I then cut out a 0.32" hole for the DC jack using a wizard as well.
    All this was done using a 1/8" slot mill bit.
    The only problem was that I used a male DB-9 instead of a Female. That 's what happens when you are still working at midnight. I'll probably not change it as I used locktite on the dB-9 mounting screws.
    Next job is to wire up the cable between the Pendant and the dicast box.
    Cheers,
    Peter.
    Attached Thumbnails Attached Thumbnails DSCN0632.jpg   DSCN0633.jpg   DSCN0643.jpg   DSCN0645.jpg
    Aug 2005
    1101
    Hi All,
    I finally finished the hardware for the pendant last night. There wasn't too much to do apart from wire up the Pendant lead cable and connector. I did a quick check and all control and the display are working. Attached is a photo of the finished pendant (Excluding labelling of the controls)
    The next task is to write the macropump to control the pendants functionality. I'm not sure as to how I will use all the switches and Leds yet. I have the following at my disposal;
    • 100 ppr MPG
    • 1 potentiometer
    • 6 pushbuttons
    • 7 Led indicators
    • 4x20 LCD.
    So,
    Cycle Start Bottom Left Button
    Feed Hold Bottom Right Button
    Spindle Toggle Top Left Button
    FRO Top right Potentiometer
    etc.
    Any ideas welcome.
    Cheers,
    Peter.
    Mar 2005
    35
    Beautiful!!
    Well, I want one! Will you be selling these on your site? Worked out a price yet? Looks great! Good job, Peter.
    Doug
    Aug 2005
    1101
    Quote Originally Posted by d.dixson View Post
    Doug
    Hi Doug,
    Thanks for the complement. You know, I didn't start out with the express goal to produce a Kit as such, but more as a DIY pendant that people could put together. I 'm doing a talk on Modbus and the ModIO at the CNC BBQ on Saturday and needed a Testbed for the talk so I figured that the pendant would be a good way to go, and something people could take away.
    That said, I've had a number of similar enquiries about selling a Kit, so I think I will go ahead with it. The one thing I'm dreading though is doing step by step instructions.
    I'll put a price list together next week, once the BBQ is over.
    Cheers,
    Peter.
    May 2007
    715
    Ad one more the the waiting list then. This is a great idea for a Kit of this product.
    I already have one pendant, but I really like the idea of the display on this one for quick reference.
    Keep up the good work!!
    Dec 2006
    252
    I am going to make a nice little pendant loosely based on this that I plan on selling it wont have the screen or the modIO but will work awesome I gots a special trick I am going to try this weekend. If this pans out would any of you be interested in it if I can keep the price per unit to 100 each?
    PM me if your interested I might be looking to get a few beta testers some units to help me with feedback
    Coog
    Building Stage:[xxxxxxxxxxxxxxxxxxxx] 105%
    Finishing Stage:[xxxxxxxxxxxxxxxxxxx-] 95%
Page 1 of 6 123
  1. Mach3 Diy Pendant Schematic
    By xlukkajr in forum Mach Wizards, Macros, & Addons
    Last Post: 03-07-2014, 07:45 AM
  2. MPG-0031 Handheld Pendant
    By Wm McNett in forum Fadal
    Last Post: 09-21-2009, 04:31 AM
  3. Micronor MR175 Handheld Pendant
    By Wm McNett in forum CNC Machine Related Electronics
    Last Post: 05-09-2008, 03:59 AM
  4. Hirata Teach Pendant H-3660 & Mach3?
    By bigz1 in forum Mach Wizards, Macros, & Addons
    Last Post: 08-07-2007, 11:10 PM
  5. Mach3 and Tormach pendant
    By jfc11 in forum Mach Software (ArtSoft software)
    Last Post: 01-31-2007, 01:24 AM
