587,426 active members*
4,545 visitors online*
    Mar 2006
    38
    Mach 3 Start, Stop Buttons
    I have followed all the directions that I can find and it still does not work.
    Ports and Pins, OEM 1&2, Port 1, Pins 11 & 13, (Start & Stop).
    Above results same if manual or automatic.
    On Diagnostics screen "Raw Port Import Bits":
    Pin 10? lit, goes out if E Stop is activated. 6th from right, top.
    Pin 12? lit, goes out if limits are activated. 7th from right, top.
    This is where the problem stats or does not start.
    When the Start button is pressed the pin 8? lights. 5th from right, top.
    Machine program does not start.
    I have not ran the program from the keyboard to evaluate the stop key but the program wil start from the keyboard.
    I have been running this machine for over a year with Mach3 and the old Blue Screen Set with Probe. After adding Big Tex, and not liking it. I reloaded Mach3 and the Blue Screen Set. This is where the problems started.
    Grandpa Jay
    35538
    Do you have external buttons wired? I'm confused, because you're talking about the keyboard??
    Go to Config>Hotkeys and enter the OEM codes for Start (1000) and Stop (1003) for their respective OEM Triggers. See if that works.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2006
    38
    Red face
    Thank you very much.
    If I would do what it says instead of what I think that it said it would be better. I'm not getting old, grandma died at 97, I still have 25 years to go.
    Grandpa Jay
  1. Start push buttons Biesse Rover 13 does`nt light
    By Christiaan in forum CNC Machining Centers
    Last Post: 11-23-2021, 09:52 PM
  2. How to wire E-Stop Buttons and Limit Switches which Pin in Printer Port
    By guy2b1 in forum CNC Machine Related Electronics
    Last Post: 06-09-2009, 01:36 PM
  3. Mach 3 buttons missing
    By FandZ in forum Mach Software (ArtSoft software)
    Last Post: 04-26-2009, 08:07 AM
  4. external start stop
    By drk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2005, 05:21 PM
  5. Stop/start a program
    By jimglass in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2003, 02:59 PM
