Lubrication
It seems that most somewhat affordable linear bearing and ballscrew machines are built with no provision or thought towards lubrication. They get run with whatever grease is already in the balls until they start to die.
I have one professional machine, and it has a pneumatic power hydraulic oiler that puts a drop of oil on every primary lubrication point every 15 minutes. My Taig has no provision for lubrication at all. I've taken to applying way oil to every thing on it with a paint brush every few hours. Thats kind of awkward if its in the middle of a 9 hour cut. LOL. My little Chinese router has round rails and cheap ballscrews with no easy way to lubricate them. They appear to have been originally grease lubricated, but there aren't any grease zerks or easy oil point for long term lubrication.
What got me thinking about this a combination of things.
I recently stuck the quill on my big mill because at some point it was run without oil, and it scored the quill and the liner. The oil it was getting was not distributing well enough after that for the 3D machining it was doing at the time. Nothing I can do about that now. The damage was done before I got it. I am building a "companion" spindle (full Z assembly) to go on the front of the head on that mill using a cheap ballscrew assembly purchased on-line. (Its temporary - when I get current paid jobs done I'll build a new one or rebuild that one with a better ballscrew) Its ok for the price, but has the same issues as most ballscrew and round rail assemblies. No obvious way to keep it lubricated or relubricate.
I also have parts accumulating for a couple machine builds. All of the ballscrews I have seem to have a hole in the flange, but I don't know if that is a lube point or not. There is no cap or zerk there. I've also got supported round rails with half bearings, and square rails with bearing blocks. The round rails and bearings also have no obvious lubrication points. The square rails are mostly THK purchased as the opportunity arose and deals were found. The square rails all have what appears to be a tiny little grease zerk on the bearing block.
Help please.
Lubrication and relubricating your average 1605 (or similar) Chinese ballscrews.
Lubrication and relubricating for supported round rail bearing blocks.
Lubrication and relubricating THK (or similar) square rail bearing blocks.
Bob La Londe
http://www.YumaBassMan.com
