587,449 active members*
2,471 visitors online*
Thread: low amps
    Apr 2008
    6
    Smile low amps
    hi all, just wondering if it's ok to connect a driver board rated at 2.5 per axis to motors that are rated at 3.5 amps? Chris.
    Mar 2008
    267
    Yes it is ...BUT...
    Make sure You include a current limiting resistor in series with the higher current motor.
    what value You ask? That depends on the voltage You are driving the motor with and the voltage at which the motor draws the 3.5 Amps.
    The oucome is that the torque will be reduced but You will get usable motion ( as in dynamics not what happens after a big meal) from the motor.
    Feb 2007
    966
    Do you mean a stepper motor ? If so then the driver board will only output its set current. You don't need a limiting resistor.
  1. enough amps ?
    By gaffa in forum Controller & Computer Solutions
    Last Post: 02-27-2009, 08:48 PM
  2. Help with AMC amps
    By ka67_72 in forum Servo Motors / Drives
    Last Post: 02-20-2009, 01:51 AM
  3. 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ...
    By kochevnik in forum Stepper Motors / Drives
    Last Post: 10-23-2006, 04:48 AM
  4. How many amps ?
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 03-10-2006, 02:48 AM
  5. Howto find input amps, from output amps on transformer?
    By sendkeys in forum CNC Machine Related Electronics
    Last Post: 07-15-2004, 01:13 AM
