i am working on a file that has a couple of .stl files converted to polygonal mesh. everything was fine and i got it all programmed initialy, but now i can't see or select one of the meshes. everything is on it's own level so i can turn all the level but the one with this mesh on it off, and it shows up on the screen statistics, so i know it's there.
it's not hidden as far as i can tell, but i've tried just hitting the hide button, which is supposed to unhide any hidden entities, and i've tried hitting the unhide some function using select all. no dice
i've tried hitting select all then attributes to change the color of the mesh in case i accidentally changed it to the same as my background color. no dice
now i've made a change on one of the tools used on that geometry. it went dirty and won't re-gen.
anyone had this problem before?
any ideas?
unfortunately, i can't post this file, and i imagine that if i could replicate the problem in a file i could post i would then be able to solve this problem.
thanks for any help.
