587,278 active members*
3,319 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > looking for distributor fiber laser marking machine
Results 1 to 1 of 1
Hybrid View
    Apr 2011
    69
    1)Product introduction
    Optical fiber laser marking machine applied the laser marking machine system that was reseached and developed and manufactured by the most advanced laser technology in the world. It uses made-in-china fiber laser output,the quality a little bit unstable than german IPG fiber.
    2)Advantages
    1. Its processing speed is a traditional marking machine 2-3 times which is very fast.Electromechanical light conversion efficiency of optical fiber laser marking machine is very high, the power consumption is less than 500W which is 1/10 of a lamp pumped solid laser marking machine,so it can save energy consumption expenditure.
    2. Its beam quality is little be good than traditional solid laser marking machine and it is base model (TEM00) output and its focusing flare diameter is less than 20um.Divergence Angle is 1/4 of laser diode pumped.It is especially suitable for fine, precision marking.
    3. The function of marking software is powerful,is compatible Coreldraw, AutoCAD, Photoshop etc.software files; support PLT, PCX, DXF, BMP, etc, can use directly SHX and TTF fonts; support the automatic coding, print serial number, batch number, date, bar code, two dimensional barcode, automatic jump number, etc.
    3)Areas of application:
    Optical fiber laser marking machine has already been used in electronic industry and automobile industry, tools and measuring tools, aerospace, instrumentation, packaging industry, medical products, household appliances, keyboard, panel, advertising signs, certificates CARDS, daily articles, diamond jewellery, etc.
    1. applicable industries: mobile phone key-press, plastic pervious to light buttons, electronic components, integrated circuit (IC), electrical appliances, communication products, sanitary ware, tool accessories, cutting tools, glasses clocks and watches, jewelry, auto parts, bags decorative clasp, cookware, stainless steel products, etc.
    2.Applicable materials: any metal (including rare metal), engineering plastic, electroplating materials, coating material, coating materials, plastic rubber, epoxy resin, ceramics, etc
    4)Technology Parameter:
    Type: FM-20W
    Biggest laser power: 20W
    Laser wavelength: 1064nm
    Power adjustment range:0-100%
    Beam quality: M2 < 1.5
    Laser repeat frequency:20- 80KHz
    Marking scope: 100 x 100mm
    Marking depth: ≤0.2 mm
    Minimum focusing flare: 0.008 mm
    Minimum character height: 0.18 mm
    Maximum linear marking speed: 12000mm/s
    Standard sculpture range: 100mm x 100mm
    Matching sculpture range: 50 x 50 150mm x 150mm
    Control interface: USB
    Lasermodule life: > 100000 hours
    Repeat precision:±0.001mm
    The power consumption: < 0.5 KW
    Electrical source: 220V±22V/ 50Hz / 12A
    Galvanometer scanning galvanometer: high performance
    Cooling mode: high-precision temperature/closed loop cooling
    Appearance size:410mmx 650mm xx 1200mm
    Weight: 150KG
    always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: [email protected] Skype:lisaseekcn
  1. fiber marking machine
    By wklaserliu in forum News Announcements
    Last Post: 09-08-2012, 08:34 AM
  2. looking for distributor for fiber laser marking machine
    By hanzlaser in forum News Announcements
    Last Post: 07-21-2012, 07:47 AM
  3. sell portable fiber laser marking machine
    Last Post: 09-22-2011, 05:08 AM
