587,913 active members*
3,650 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Long length engraving bits / needle
Results 1 to 7 of 7
    Sep 2012
    0
    Angry Long length engraving bits / needle
    Hi everyone, first time poster here so unsure if this is the correct section of the forum, there are quite a few eh.
    I'm in a bit of a pickle at the minute, I've just bought an engraving machine and I'm wanting to change the bit to do some PCB's.
    The current bit (I'll try and get some pictures) resembles a blunt pencil currently...
    I'm wanting one of these -
    1/8 x 4-1/2 Cutters : Bits & Bits
    But I can't find them on-line, let alone in the UK.
    Can someone tell me what they're called? Or perhaps provide a link to somewhere or someone who can sell me one/some?
    This is really killing my excitement for my new projects as well as having my own CNC machine.
    Any help would be greatly appreciated!
    Many thanks
    Chris
    May 2012
    0
    Hi Chris,
    The top photo is a single flute engraving tool. You may be able to get both at a company like Harvey Tool in the US.
    Find Specialty Carbide End Mills and Cutting Tools at Harvey Tool
    Harvey Tool - Carbide Engraving Cutters from 30 to 120 Degrees at Harvey Tool!
    Kim
    Sep 2012
    0
    Thanks Kim, that's really helpful. I was hoping to get them from the UK as I'll no doubt want different type from time to time and don't really want to have to have long lead times waiting for bits etc.
    I don't think the import duty will count due to the weight of the object eh.
    Any one else have any other suggestions?
    Cheers!
    Jan 2007
    1795
    halfround engraving bit..
    the long type is designed for top loading
    generally, the toploading makes the set easier.. when it touch surface you can lock the bit..
    onsrud, and bitsbits has this type tool yet...
    Engraving Bits
    but i dont know if they send to england..
    if you were using cnc, what works with er collet, the ebay also has million of bit..different angles, and small dia halfround cutters..
    Feb 2011
    423
    Any tool grinder can make these for you cheaper than you can import them.
    Sep 2012
    0
    Quote Originally Posted by victorofga View Post
    Engraving Bits
    Thanks for your reply! I'm going to be changig over to a Kress 1050 soon enough, but I want to test the setup as it is before I go tearing it apart. Getting it to communicate with the PC is being enough of a task in its own right
    I'll have to have a look around to see if someone could make the bit for me, otherwise I'll just have to go and import them and take the sting I think.
    I would have thought it would have been something readily available within the "engraving" community yano? I've ordered some of the collet type bits from ebay, and this is how I've come to realise the stage I'm at
    I'll check out those links and see what I can find. I think it might just be easier to upgrade to the Kress and just get on with it
    Thanks again all, ever helpful!
    Sep 2012
    0
    Quote Originally Posted by slowlearner View Post
    Ahh nice one, thanks, I'll get Googling and see if I can someone locally :cheers:
  1. tool length to long
    By laamar in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-15-2021, 11:02 PM
  2. accurate length on long parts - methods?
    By pmurdock in forum Haas Lathes
    Last Post: 06-16-2012, 09:43 PM
  3. extended length router bits
    By justCNCit in forum DIY CNC Router Table Machines
    Last Post: 12-09-2009, 08:43 PM
  4. Long Bits
    By telmoff in forum Want To Buy...Need help!
    Last Post: 02-26-2009, 11:41 PM
  5. Need Extra Long Ball End Mills (12"overall length)
    By CADkathy in forum Toolgrinding / Toolgrinding Machines
    Last Post: 02-18-2005, 04:54 AM
