Log Carving with the Saturn 2
Only try this with a machine with enough Z clearance, NEMA 34 motors and at least a 2 1/2 Hp spindle or router. I used a 1/2 inch 13 mm bit and took just a .2 deep cut to make level about 1 inch or 25 mm taken off.
The Bear is from Design & Make collection, VCarve Pro 9.5.
Bear was done with 1/4 inch 6 mm Roughing and 1/8 inch 3 mm ball nose bit for Finish. Did not take that long.
Did not turn out that well, wood was stringy and hard to get a good finish on, but I am just trying the concept.
Can't seem to arrange the pictures in the correct order??
Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
