587,421 active members*
3,321 visitors online*
    Feb 2014
    3
    LinuxCNC 2.x Laser component problem
    Hello all!
    I am making a small laser cutter/engraver CNC with a diode laser.
    I have set my system with linuxCNC and the M3/M4 work with the laser driver nicely. I am glad that those guys from buildlog made that great piece of software!
    The problem is that the magic Z function won't turn on the laser. The "Test fire laser" button near the magic Z trigger will raise a "Unable to open <146> file" flag. I know that there is a 146.ngc file with a gCode subroutine but I can't figure out how to fix this issue.
    Is there something I am doing wrong?
    I have set my HAL and INI file with my LPT pins and everything else works ("new build" thread coming when the laser diode arrives...)
    Thanks for your time!
    Jan 2008
    1542
    I get the same error when I press the button, I believe it's due to not having the file in the right place. Needs to be in the NC files directory I think.
    My laser works fine with M3/M4. I haven't bothered moving the 146 file because I have a physical test fire button
    Jun 2012
    16
    Re: LinuxCNC 2.x Laser component problem
    John
    I am using the linuxcnc 2.7.3 and running a laser, have you updated and/or have your laser running.
    If so would you be good enough to forward me the .hal .xml etc etc files for the setup, there is not a lot out there for laser
    thanks Doug
    - - - Updated - - -
    Pippin88
    thanks Doug
  1. problem with my LinuxCNC
    By lordx in forum LinuxCNC (formerly EMC2)
    Last Post: 03-06-2017, 12:05 PM
  2. LinuxCNC laser control (or why you don't need a DSP)
    By pippin88 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2013, 02:10 PM
  3. LinuxCNC laser cutters and gcode generation
    By fishface in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-23-2012, 11:25 PM
  4. "ActiveX component can't create object" problem
    By hownewsday in forum Mastercam
    Last Post: 03-06-2011, 01:06 AM
