587,579 active members*
3,471 visitors online*
IndustryArena Forum > CNC Electronics > PIC Programing / Design > Lini-Stepper Revisited ( Hacked )
Page 1 of 6 123
Results 1 to 20 of 104
    Dec 2005
    77
    My first idea was to build some new drivers for my PCB mill.
    LiniSteppers , as these have micro stepping modes.
    but i was not so keen on the heat that these generate.
    After a bit more thought and a bit of hacking ,
    I came up with this new design using IRFz 44 Mosfet's
    instead of the Tip 122 transistors that were used in the LiniSteppers.
    Using the code of the LiniStepper , with a few modifications , a new
    PCB was created in eagle , then using the direct print to PCB method
    a new board was produced and assembled.
    This can handle a lot more amps and very little heat without any
    heatsinks at all. Also including on board 5 volt regulators for the
    supply for the PIC 16F84a micro that is used.
    ( due to a brain fade during printing of the PCB the Mosfet's :withstupi
    are actually reversed in the photo and the 5 volt reg should
    be at the Top of the photo - oh bugger )
    Kym
    Attached Thumbnails Attached Thumbnails STEPIT.jpg   STEPIT LAYOUT.jpg   STEPPER DRIVER.jpg
    Attached Files Attached Files
    Jun 2003
    3312
    So how are you determining the phase currents to limit the values? i.e. using a 24V Supply with a 2.2A motor vs using a 30V supply with a 1A motor?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Dec 2005
    77
    Quote Originally Posted by pminmo View Post
    You mean limit the current to the motors ?
    I an running hp laser jet motors 5.2 volts at 1.4 amps with a constant
    current supply at 35 volts:
    The voltage being variable while the current is stable:
    Kym
    Jun 2003
    3312
    Ok, I thought you were doing something other than full step.
    Dec 2005
    77
    Full step , 1/2 step , 1/6 step , 1/18 step , just as
    the Lini-Steppers but without the adjustable drive:
    Kym
    Jun 2003
    3312
    The linistepper can control phase current by utilizing the bipolars in the linear region. Your circuit doesn't look like it can do that. Other than contolling duty cycle by phase in which case you would have to readjust your supply current. What am I missing?
    Dec 2005
    77
    I am thinking, you have down loaded the ZIP file, which contains the
    much reduced Lini-stepper source code, compiled hex file and eagle board
    file :
    The PWM loop is the output to the Fet's, the Phasing of which is
    set in the Mode-3600, Mode-1200, Mode-400 and Mode-200 loops:
    switching the Fet's off or on
    The other half of the code , which is removed , is for setting the
    bias to the transistors to allow different current levels in different modes:
    As seeing is believing ,grab a breadboard and do a quick mock up of the circuit
    Kym
    Jun 2003
    3312
    If it is doing pwm duty cycle for current determination, it will work. But a single current limited source would probably limit you to 70% of the available motor power and keep coil currents in spec.
    May 2006
    6
    Talking steppit update
    dear fellow cnc'ers using linistepper
    I had designed a pcb layout for above.
    Additional features are.
    1. all floating inputs are tied low
    step direction and speed selection inputs
    2. clock generator using 555 using full functionality of 555 chip
    ie upto 500khz clock speed
    3. 1/4 clock indicator of the motor.. beginning pulse detector indicated
    by LED.
    4. current limiting option for higher voltages marked by A, B, C.
    see attached attachment in pdf format.
    will try out this in this weekend till then
    have fun
    dr.sanjeevi rao s from visakhapatnam India
    May 2005
    1397
    Just to make sure everyone understands, this is really not a Linistepper anymore. It can't microstep (only half step) and it doesn't have any of the analogue current regulation features that are part of the Linistepper design.
    As far as I can see, the only thing this controller has in common with the Linistepper is that PART of the source code was re-used. It cannot do any of the firmware microstepping that the lini uses to get 3600 steps/rev.
    As far as the operating temperature and the need (or not) for heatsinks: There has apparently been a huge misunderstanding here. The Linistepper can be operated in Full or Half step modes with the exact same thermal efficiency. The Lini only gets hot when you go up into microstepping modes because that is where the power drivers start to be used in a partially on mode. In Full or Half step, the Linistepper drives the transistors fully on or fully off just as this "hacked" version does.
    While the Linistepper source code is open source and we are happy to see anyone getting good use from it, this driver really should NOT be reffered to as a Linistepper in any way at all. I would very much appreciate it if the thread owner can edit the title or at least make it very clear that:
    THIS IS NOT A LINISTEPPER.
    Thank you!
    Dec 2005
    77
    To James newton
    I have never claimed this to be a LINI-STEPPER > other than borrowing
    the freely available source code ( thanks very much ).
    ANYONE WHO CAN SEE WILL BE ABLE TO TELL THE DIFFERENCE.
    By the way keep up the good work on the website.
    Kym
    Nov 2007
    72
    Question.
    I knew there is hardware design doing the micro-steps, are there any software solution for micro-steps?
    May 2007
    42
    hello kowell
    this is my first post n i would like to know if i can replace 16f84a with 16f628a without any change in code ? as this ic is cheaper in india and can i replace the mosfets with
    MP102 or SMA4033 darlington qaud transisitors as i have plenty of them lying around !
    thanks
    sahil
    Feb 2007
    532
    You should be able to change the code to work in a 16F628 without too much trouble.
    You will need to add some initialization code for the ports on the 628, as on startup some of the pins are configured as analog inputs/outputs for the comprator, which the 16F84 doesn't have.
    May 2007
    42
    thanks kiwichris , can anyone of you guys make the required changes and post the code as i'm only good at pic basic pro programming and asm. is kinda not my thing .
    thanks
    sahil
    Feb 2007
    532
    Quote Originally Posted by sahilkit View Post
    thanks
    sahil
    Hi-ho,
    To disable the comparator you just need to lob the following code in the port before the port initialization code:
    movlw 07h
    movwf CMCON
    ie: Write 07 into the CMCON register.
    Aside from that 16F84 code generally works in a 16F628 in my experience...
    Cheers, Chris H.
    Feb 2007
    532
    Just remembered.....
    You need to be in register page 0 to do that, so just to be sure, make that code:
    bcf STATUS,RP0 ; select register page 0
    bcf STATUS,RP1
    movlw 07h ; turns off comparator.
    movwf CMCON
    Must stop replying to my own posts, rather bad form, what.... :-).
    Nov 2006
    90
    Here be the code that will make your chips smile :)
    Here you go.
    The original creator of this code was very thoughtful, as he added some compiler directives that change the output HEX file to suit either the '628A, or the '84.
    The included HEX file will run on your PIC16F628A chips. I can confirm this, as I am using 3 of them to run my machine's motors.
    Note: The file I have uploaded, is a HEX file, not a TXT file, so be sure to change the extension back to HEX.
    Have fun, and happy CNC-ing to you .
    Best wishes,
    Steven-tee.
    Mar 2005
    523
    hello Steve-Tee
    would you have and would you post the asm version of this hex (txt) file.
    thanks garry
    Dec 2005
    77
    Angry
    Thanks for the help guys
    Hard Disk crash this way , so most of the files were lost and I am in the
    process of recovering them:
    So after downloading my own zip file , have Re-compiled for a 16F628
    while not tested on a real 16F628 , it should work.
    The new Zip contains the asm source files and compiled Hex files for
    both chip types , 16F84A and 16F628.
    As for using different Fets , as long as they are logic level devices they
    should work.
    Kym
Page 1 of 6 123
  1. Lini-Stepper Revisited ( hacked )
    By kowell in forum PIC Programing / Design
    Last Post: 06-29-2007, 12:12 PM
  2. My hacked HP printer flatbed
    By Graham S in forum CNC Machine Related Electronics
    Last Post: 06-02-2007, 11:31 PM
  3. Lini Mod
    By OCNC in forum PIC Programing / Design
    Last Post: 07-25-2006, 04:19 AM
