586,553 active members*
3,393 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion
IndustryArena Forum: Linear and Rotary Motion
Page 11 of 130 9101112132161111
Threads 201 to 220 of 2584
Discuss ball/Acme screws, R&P, linear slides and theory here.
  1. Sticky Thread Sticky: Ballscrew Basics
    Started by Swede, 03-01-2005 05:06 PM
    7 Pages
    1 2 3 4 5 ... 7
    04-25-2024, 08:37 AM Go to last post
  2. Sticky Thread Sticky: Servo or Stepper for CNC?
    Started by CNC_Kid, 02-05-2006 08:37 PM
    4 Pages
    1 2 3 4
    cnc, cutting, plasma, run, servo, wan
    08-06-2021, 02:21 PM Go to last post
    03-16-2021, 08:26 PM Go to last post
  3. Poll Sticky Thread Sticky: Poll: Screw Threads 101
    Started by widgitmaster, 05-20-2006 02:37 PM
    3 Pages
    1 2 3
    05-04-2015, 09:31 PM Go to last post
  1. Strain wave gear principle - Harmonic Drive AG
    Started by Brian_vz, 07-19-2019 12:57 AM
    cad, cnc, gear, math, software
    07-19-2019, 08:59 AM Go to last post
  2. Question CNC Shaft Couplings, Whats out there?
    Started by umfan110, 07-02-2019 02:28 PM
    cnc, coupler, guys, shaft, threaded
    07-03-2019, 06:42 AM Go to last post
  3. who to buy linear rail/bearings from
    Started by tkms002, 01-04-2019 05:58 PM
    2 Pages
    1 2
    bearings, linear, lot, profile, seller
    07-01-2019, 10:28 AM Go to last post
  4. Anti-whipping ballscrew idea
    Started by Black Forest, 11-02-2016 10:46 PM
    ballscrew, linear, nut, screw, whipping
    06-30-2019, 06:57 PM Go to last post
  5. Timing pulley slipping on gearbox shaft
    Started by WilliamKinsey, 06-15-2019 06:49 AM
    06-23-2019, 05:48 AM Go to last post
  6. CNC Router, no preload - what are the consequences
    Started by Nicksch, 06-07-2019 04:38 AM
    4ft, bearings, cnc, preload, router
    06-10-2019, 10:15 AM Go to last post
  7. Query with Ball Screws and Lead Screws
    Started by maxbest, 06-05-2019 08:10 PM
    06-08-2019, 01:36 AM Go to last post
    06-05-2019, 04:05 AM Go to last post
  8. Indraworks software
    Started by James-Ross, 05-26-2019 02:24 PM
    drive, indraworks, interface, software, type
    05-26-2019, 02:24 PM Go to last post
  9. How many balls in nut?
    Started by phantomcow2, 08-05-2006 07:10 PM
    amount, ballnut, balls, make, wan, worked
    05-19-2019, 04:51 PM Go to last post
  10. Matching bearing for rotary shaft
    Started by sh2005, 05-01-2019 01:02 AM
    bearing, bearings, fit, press, shaft
    05-01-2019, 06:50 PM Go to last post
  11. Reballing linear blocks / wagons / carts
    Started by ack1, 04-28-2019 07:26 PM
    bad, balls, blocks, replace, thought
    04-29-2019, 08:46 PM Go to last post
  12. SINGLE START AND DOUBLE START NUT
    Started by huongnhat, 04-16-2019 01:27 PM
    ball screw, nut, problem, screw, start
    04-23-2019, 11:26 PM Go to last post
  13. THK Linear Guides - Rigidity For Lathe
    Started by yngndrw, 04-04-2019 11:45 AM
    axis, lathe, spindle, thk, turret
    04-13-2019, 12:22 AM Go to last post
  14. 4th Axis Conversion
    Started by Jim Dawson, 12-20-2016 01:46 AM
    04-07-2019, 07:29 PM Go to last post
    04-04-2019, 07:20 AM Go to last post
  15. Question Having trouble with lineer rails flatness.
    Started by Kaan84, 04-02-2019 11:05 AM
    04-03-2019, 08:53 PM Go to last post
  16. Ballscrew and nut mismatch
    Started by rkcsx4, 03-26-2019 04:56 PM
    5mm, ballnut, inch, leadscrew, pitch
    03-28-2019, 09:41 PM Go to last post
  17. Question Ballscrew Floating Support
    Started by yngndrw, 03-25-2019 11:09 AM
    axially, ballscrew, housing, slide, support
    03-26-2019, 02:47 AM Go to last post
  18. Typical SFU1605 runout?
    Started by db112358, 03-11-2019 02:44 PM
    end, microns, noticed, rails, runout
    03-11-2019, 02:44 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
