587,507 active members*
3,099 visitors online*
Results 1 to 17 of 17
    Mar 2006
    233
    Linear guide resistance...
    I am putting together my machine and I have the x axis rails and bearings installed. They are HIWIN LG series 20mm rails and blocks. The bearings that I bought have a p/n designation that says they have a "light preload". I have 2 on each side of the machine for a total of 4. When I move them back and fourth by hand there is a noticable amount of resistance. Not a ton but a decent amount. They run smooth but are just stiff. Will these wear in and be easier to move or should I have bought the non preload version? My machine will be moved by steppers and I am wondering if this will affect the machine in any way?
    Mar 2009
    624
    No this is quite normal so long has it's not too excessive and is even all along the rails length.
    If you give them an average push they should slide for a short distance the stop gently IE not in a harsh abrupt gerky stop.
    They will free off slightly under use but not too much, they will feel smoother when they have weight on them as well.
    My rails did this also and it worried me too.!!. . . . But worrie not.
    Apr 2009
    5516
    hemsworthlad hit on something that I found out tuning my x axis - the key is having an even feel thoughout. Definitely don't want it tight, then free, then tight or such. Between the steppers and leadscrews, they can output a lot of force, more than one may realize....
    Mar 2006
    233
    The resistance is even along the rail. However you can not just give it an average shove and have it coast for a bit, it will stop almost immediately. There seems to be a little bit more resistance than what I was expecting but at the same time it does not feel excessive or like something is in a bind. Its feels almost like there is a set screw that adjust the tension that is set just a tiny bit too tight.
    Jul 2009
    140
    I wonder if the rails were coated with some sort of heavy grease to keep them from rusting? That would certainly slow up your movement. Give that a good wipe with some solvent on a rag...wear gloves and a respirator, though!
    Mar 2006
    233
    Yeah they do have a super heavy coat of grease on them. Its not real thick but it is there.
    Mar 2009
    624
    Yes this may be causing it, do what CK says and clean it off but only the rails the bearings obviously need to be greased.
    I think you'll find they will be fine and so long as there is no obvious binding or sticking then you wont have a problem.
    When i say a short distance i do mean only 6 or 8 inch and not 2-3 feet.!!
    I,ve just been and tested some rails that i have here for another project, not hi-win but equivelents and if i line the end of the bearing with a hole on the rail and flick the bearing hard with my index finger on the edge thats lined with the hole then it travels between 3 and 4 holes the holes have 60mm centers.
    Hope this helps.
    Dec 2006
    38
    Same issue here. I ordered the LG "light" preload because the light and very-light were said to be negligible in the felt difference. I went from V-rail and bearings to LG 20 series and you just can't push the blocks and have them move freely. I have tried to clean the rail and it feels better than it was, however still no free movement.
    Mar 2009
    624
    Quote Originally Posted by madtownrob View Post
    You'll be surpised just how free they slide when you have the full weight of the gantry etc mounted onto them.!!
    If they are still very stiff when the gantry etc is attached then i would be concerned and start looking to see if the rails are mounted correctly and straight, it doesn't take much missalignment to cause them to bhind.
    Mar 2006
    233
    There is no pushing or flicking them and having them coast ANY period. I am glad someone else noticed. The rails are mounted but even with no gantry pieces installed and nothing to even try and make it rack or bind the result is the same. I have 6 of these blocks and all 6 feel the exact same.
    Sep 2006
    87
    Quote Originally Posted by SatanKlawz View Post
    I also have some hiwin equivalent, they look pretty decent quality.
    and they are also stiff. they wont coast either.
    i have yet to properly test if this is an issue or not, as the gantry is not in place yet. They are much stiffer than i would have anticipated, but then again, it's the first time i used such rails, so beware of preconceived ideas !
    It may all be completely normal.
    try this test maybe: hang the rails vertically, and hook up some weigths on the carriage until it starts moving from gravity only.
    then tell us how much weight that was.
    knowing your stepper torque will tell you if you are miles out, and if they are indeed too stiff.
    Mar 2006
    233
    These rails and blocks are rated for some prety serious loads. I get the feeling that this is normal for a block that can handle such a high load and stay true to its linear path. I do not think its a deal killer at all it was just more than I expected.
    Dec 2006
    38
    Ya - I have the super heavy duty long flanged blocks on my build and are overkill. I had some ebay surplus rails (Iko and THK I think) and they wee very broken in that I was using to mock up my design. I could easily push the blocks and have them go from one side to the other. I was kind of expecting the same motion for my gantry with the new rails. I can still jog at 700ipm with a CNCRouterParts R&P with a 387 keling stepper on each side with my 125lb gantry so I guess it's no big deal. Just not what I was expecting after mocking things up with the "gently" used ebay bearings (ya right :bs
    Mar 2006
    233
    I am using the same steppers. I would say that my gantry weighs around 50 lbs. loaded up. If the motors are rated at 387oz. What type of mechanical advantage will the screw generate? I have 1/2-10, 5 start screws.
    Dec 2006
    38
    I haven't figured out the math but when my last gantry was made of MDF - it was similar in weight and I had the same 2 turn per inch screws and Dumpster AB nuts. I literally had a hard time stopping the gantry at a slower jog (say 60ipm) and it would push or pull me across the garage floor (I am 250lbs) I could get it to stall/miss steps when I was jogging at full speed (250ipm) on that machine.
    Mar 2006
    233
    Ok cool, no worries then....... I would say it takes at least a good 5lbs. of force to get it moving. I should have it going here in the next week or so. I will report back...
    May 2008
    1185
    The new cart wiper seals will have a lot of drag when new but will smooth out in time.
    If you want to feel how they will roll after break in just remove the wiper seals and give them a roll.
    I am running the 35mm rails and they were a bit stiff when new but not any more.
    These rails have been stored for a few years now so the plastic parts may be getting a bit hard.
  1. Choise the right linear guide
    By Cardedon in forum DIY CNC Router Table Machines
    Last Post: 03-31-2008, 07:56 AM
  2. Fuse And Linear Guide
    By Alex S.A in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2007, 11:48 PM
  3. Guide Blocks or Linear Shaft?
    By mre1000 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2005, 01:38 PM
  4. Support for linear guide
    By wile_e in forum Mechanical Calculations/Engineering Design
    Last Post: 01-30-2005, 12:30 AM
  5. Delrin T Linear Guide Systems
    By Moondog in forum DIY CNC Router Table Machines
    Last Post: 07-06-2004, 02:02 AM
